Question about Tomtom GO 910 GPS Receiver
910 wont turn on,green light comes on in cradle or when I press and hold start button. Have tried reset but it still wont come on. Ken Collyer
  • Anonymous Mar 05, 2009
    I have a similar problem except that the green light comes on when the unit is in the cradle, pressing the power button doesn't do anything at all (no green light and the unit remains off). I have tried pressing the reset button several time. Any help greatly appreciated.
    Thnx, Rich
Hi i have had the same problem with mine, its a problem with the start up files, plug it in to the pc and also the wall charger, it should then recognise it and then ask to scan and fix the problems once it does that its all fixed, cheers
Posted on Mar 01, 2009
Hi my tom tom go910 wont turn on but the green light is on when its connected to the charger
First, check and make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Sep 17, 2011 | Tomtom GO 910 GPS Receiver
All of a sudden my sony clie would not power up when I pressed the power. I have replaced the battery, but to no avail. answer?
Plug it into the cradle, make sure the green light on the cradle is on.
With it still in the cradle, hold down the power button, then press the reset button on the back while still holding down power button.
Initialization screen comes up, memory is cleared, do a sync to restore memory.
You will have to restore your data afterwords.
May 10, 2010 | Sony Computers & Internet
Green light comes on, but screen does light up
Tomtomone - green light comes on but screen does not light up
Jul 15, 2009 | Tomtom GO 910 GPS Receiver
Tomtom 730 doesn't switch on!
Hopefully all you need to do is a soft reset. To do this use a streightened paper clip and insert it into the small round hole marked reset on the bottom of your tt. Gently press the reset button in until you feel a click. Hold the reset button in for 20 seconds. Hope this does the job.
Jun 07, 2009 | Tomtom GO 910
PL-CS55 headset lifts receiver but only get buzzing sound in
Try a system reset:
1. Lift the headset off of the charging cradle (the base).  Make sure the headset is turned off.  The green light on the base won't be on if the headset is turned off. 2. Hold down the call answer button on the headset at the same time as mute button.  The mute button is found on the little black wheel on the top of the headset.  Use the tip of your finger to push it straight in. 3. Hold both buttons until you see a green light on the headset flash.  It will be right below your thumb.  Hold both buttons until the green light flashes for a series of 2 flashes.  Then let go of both buttons. 4. Put the headset back on the charging cradle and wait 30 seconds.  Lift it back off and try again. 5. If this doesn't work repeat the process once more or try a resubscription.
Resubscription procedure:
1. Put the headset back onto the charging cradle.  Make sure the red light on the base is on and the yellow light is flashing. 2. On the back of the base there are two buttons for the microphone adjustment that can be pressed down.  Press both of those down until the red light and yellow light on the front of the base start flashing. 3. While the headset is still on the charging cradle press and hold the mute button until the red light on the base goes solid, and the yellow light stays flashing. 4. Unplug the power to the base and then plug it back in. 5. Wait 20 seconds and try.
Apr 22, 2009 | Plantronics PL-CS55 Wireless Headset
My zen stone stays on a solid green light
Just tried this on a zen stone with speaker and worked. Connect your zen stone to your computer. When the green light is on, use a paper clip and press and hold the reset button (small hole on the headphone jack side). The green light should turn off. Wait a bit and it should start blinking to indicate it is now charging. Note: This reset only worked when I had it connected to the computer.
Hope it works for you too.
Ken
Nov 22, 2008 | Creative Labs ZEN Stone MP3 Player
TOMTOM 910 will not turn on after charging
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
GPS 910 HAS FROZEN SCREEN
First, do a reset:
http://www.tomtom.com/support/index.php?Language=4&query=reset&FID=7134
If no result, do a hard reset:
  1. Hold reset button pressed for approx 15 sec
  2. Press power button while pressing reset button
  3. Release reset button while still pressing power button
  4. Device should start, hold power button pressed until you see white text on screen, last line should read "RTC..."
  5. Release power button
Apr 29, 2008 | GPS
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 910 GPS Receiver Logo
206 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
