Does the Aquarius 100 wm 25 have a filter?
Does the Aquarius 100 wm 25 have a filter? I f so, where?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Yes.
you'll need to take the bottom rear panel off and remove the retainer from the rubber hose attached to the bottom of the drum.
it's like a plastic basket inside.
Posted on Feb 28, 2009
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
How to take bearing out of aquarius model wm63
The information for dismantling and rebuilding a Hotpoint WM washing machine is all in the workshop manual including wiring connections
Mar 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Can i clean the filter of my aquarius wash system plus WM 65 ?
Most washing machines have a screen at the water hoses. Remove the hoses on the back of the machine and remove the screens inside. They can be cleaned and reused.
Feb 19, 2009 | Washing Machines
Aquarius wash system plus wm 63
First of all lay the drain hose into a bowl or bucket to drain off.
Then take off the plate at the back of your machine and you will see a pipe running from pump to drum.
Where it meets the drum there is a filter inside which you can check for debris. also take off at the pump and check inside pipe & pump.
Happy to help further if required.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not draining therefore not spinning
You will find the filter located inside the large black hose at the lower right rear of the m/c.
Remove lower panel and you will see the hose there.
Undo the large clip and remove hose and clean filter.
Plz rate this solution
Thanks
Dec 19, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf430
Had similar problem. Blocked filter and faulty pump, clean filter replaced pump approx £25. Took about 20 mins
Jul 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius half load
you can only select half load if you wm has a half load button or switch found on the cosol panel
Feb 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wm63
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
