Question about Cyberhome CH-DVD 300 DVD Player
I have a Cyberhome CH-DVD 300 and put it in progressive scan
Since changing the video input in the menu, I can't see the screen to change it back. I use the regular yellow video output.
How can I change the setting back if I can't see the screen?
I don't have the owner's manual either.
  • 1 more comment
  • craigryff Mar 03, 2009
    To lordtango:
    Thanks for the help. I greatly appreciate it!
    Craig
  • ozzer1 Mar 08, 2009
    Thank you Lord! lol i just had the same prob after going through component and playing around w/ the menu and pro scan.the reset allowed me to see better and slowly but surely get it back to norm.
  • glw100551 Mar 13, 2009
    i have a ccanyberhome ch-dvd 300.i had it hooked up using the y-pb/cb-pr/cr plugs.now i cant get a picture or sound with the audio and video jacks.the dvd will still work on the y-pb/cb -pr/cr plugs,but the tv i want to hook it up too,does not have these plugs.only the audio and video jacks.how can i get a screen to show up ?
Turn on dvd player,leave disc tray close,press and hold in the stop button for five seconds,the dvd player will restore to factory settings and you will see the welcoming screen again,happy viewing watching your favourite dvds
Posted on Feb 28, 2009
I couldn't make the reset work ( press stop fro six seconds) until I used the switches on the unit NOT THE REMOTE. It worked first time.
Posted on Dec 06, 2009
Set to progressive scan mode no display. How to revert back?
http://www.retrevo.com/s/CyberHome-CH-DVD-300-DVD-Players-review-manual/id/534bh842/t/1-2/
Above is your manual...best to go through it as progressive scan is mentione from the beginning.
Hope i`ve helped!
Nov 30, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a (cyberhome ch-dvd 300) dvd player and changed setup menu now lost video cant see to change back is there a reset code or something
I wish I could find the website that gave all the repair hints for this DVD player, but I downloaded the info, and can no longer find the site. Here is what it says with regard to your symptoms. I hope this helps. I have done all the mods the site suggested, but continue to have difficulty with the remote, tray opening, etc. I have 2 machines and used to love them, but frustration has taken it's toll. Recovering from a condition with no TV picture
Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
"To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter.
On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
1. With the unit stopped, press Setup on the remote.
2. Press the Right Arrow Once.
3. Press Enter.
4. Press the Down Arrow 2 times.
5. Press Enter.
6. Press the Up Arrow 2 Times.
7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
To change the Parental Control setting on the CH-300 use the factory password of 3351. For the CH-400 use 1379.
Nov 02, 2009 | Televison & Video
Cyberhome dvd ch dvd 300 changed ntsc to pal by accident
I have done it! All I did was take the yellow video cord and plug it in those progressive scan plug in until I could see a blurry screen enough to be able to see to do a reset, which is under system and did a factory reset. I DID IT AND DAMN PROUD OF IT SINCE THE EXPERTS DIDN'T EVEN KNOW IT!!!!@ Jennifer pc, fl
Jun 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
2. Press Enter.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Progressive scan video compent inputs what does this do?
Dear friend,
Try this method hold "STOP" on the front of a 5sec without a disk. player change to normal mode
Oct 26, 2008 | Cyberhome CH-DVD 300 DVD Player
Need device code
i have a cyberhome dvd ch 300 and the screen has blanked out but the voice is coming through clearly. It is not showing from the usual video output but it shows very wavy on the other progressive scan lines what can i do
Jan 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Screen keeps skipping
if it is progressive scan, one of three cables or inputs may not be functioning.
Jan 14, 2008 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Blank Screen
This is almost the same problem for me...Please provide a solution
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 dvd
When I had this issue it was resolved by selecting the video input on the TV. For example: "S" video, RGB, etc. And of course check all of the connections.
Aug 15, 2007 | Cyberhome CH-DVD 300 DVD Player
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
184 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
