Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG dishwasher not working showing 1F in timer display
Turned on dishwasher tonight sounded like it drained the water out before starting same as it always does.
But i could not hear any water filling up the machine.
I left the dish washer turned on.
And after a few minutes the finished bell rang a few times and 1F was displayed in the timer window.
I Hope some one can help me and tell me what is wrong with the machine.
The display is telling me what area of the machine is not working but i dont know what part 1F is.
Regards Terry.
  • Anonymous Feb 28, 2009
    I've got the same prblm!!!The manual says "water not supplied".But not sure y...there seems to be no voltage on the solenoid at the inlet.....
  • Anonymous Mar 27, 2014
    Machine won't turn on display panel just shows 1f
  • 423 Answers
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Posted on Apr 07, 2009
  • Jeff Meyer Apr 09, 2009
    Glad to help out. Can you tell if the inlet calve screen was plugged?
    Thanks!
What can cause and lg dishwasher to not fill water and stop and show le code
Please try the plain VINEGAR in the bottom of your dishwasher. It cleans out the pipes. When you start the machine it automatically starts to drain whatever water has been left from previous cycle. When this cannot happen, due to blocked outlet pipe, it will not precede with the wash cycle. Adding the vinegar, leaving it a few hours, or overnight (hey, I left it for a week one of those times!), it is enough to liquify any heavy fats in that pipe...enough to start the cycle and the normal draining gets reinstated.Hope this helps you, it is such a pain to go & choose another dishwasher to fit into the space allowed & that has all the functions you need. This 'fix' cures all my dishwasher blues! Havagreatday!
Sep 21, 2014 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher ldf7932st motor starts but doesn't work
Is the water turned off? Dishwashers normally start a wash by emptying any waste water tipped into them during loading. Problem could therefore be a blockage somewhere, most likely in pump inflow under the filters in bottom of machine. Lift these out to check. Also check your sink drain isn't blocked and preventing the water from being pumped out.
Jan 19, 2013 | LG LDF7932ST Builtin Dishwasher
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Hello, LG LD 14AT1 dishwasher, starts cycle runs 3 minutes, starts stops on off no water in bottom. Then displays OE chimes! Checked tap under sink water there, checked filter inside bottom, turned off for...
Hi
OE in your dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. If the issue returns after cleaning then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Apr 17, 2009 | LG LDF6920ST Stainless Steel 24 in....
1 F in dispaly window
well,i have the same problem.the solenoid doesn't open for the water to flow in.... but still working on the problem....
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Aug 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
328 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
