Question about Car Audio & Video
Hi have plugged in my blaupunkt IDC A09 into my fiat punto and my radio unit recognises the cd changer and it loads and unloads electronically but wont play any of my cd's. please can you help me with a step-by-step quide on how to solve this problem. Lance
  • afroman73 Feb 28, 2009
    Hi thanks for the help but the Blaupunkt IDC A09 is the disk changer not the head unit i read in another post that its a case of marring the unit and the changer together but dont know how this is done can you help?
  • 479 Answers
This unit should be married with your radio by entering the code for radio so please go through the manuals and enter the code and confirm then only u will be getting the output.
Posted on Mar 01, 2009
  • 15,935 Answers
For instructions on Encoding your blaupunkt IDCA09 - CLICK HERE - for a PDF downlaod.
Thank you for using FixYa - a FixYa rating is appreciated!!
  • 19,396 Answers
What you are talking about , when you talk about marriage between unit is the encoding decoding setup.
You find instructions on how to do that here.
Posted on Feb 28, 2009
    Genius:
  • 1,011 Answers
Sir,
do u install the changer? if not,
1. REMOVAL OF UPPER GLOVEBOX TRIM - remove the two Torx Screws (T25 from what i remember) on the upper part of the upper glovebox trim. With these removed, pull the trim out - it is "locked" in at the bottom, so it might be slighlty hard to remove. Just ease it out from the bottom once the top is loose.
2. INSTALLATION OF CABLE - Remove the radio (2 standard radio keys), and plug in the cable (check your Radio instruction book - it's in there somewhere). Look through the hole in the upper glovebox - you can push it through to that compartment. Once you have, put the radio back in.
3. INSTALLATION OF NEW UPPER GLOVEBOX TRIM - you need a new upper glovebox trim, with a ISO radio hole. Get one from Fiat. When you get the autochanger, take the metal cage out, and place it in the new trim (it clicks into place). Push the new trim back into the glovebox, remembering to pull the cable out. Make sure it sits flush at the bottom before you screw it back, so the glovebox lid will line-up correctly again.
4. INSTALLATION OF CD AUTOCHANGER - plug in the cable, and slot into the socket! I tried putting the fixing pads Blaupunkt suggested, but Fiat told me they are not needed - I agree, as the CD changer wont fit, and it nearly broke the unit!. Push the unit in until it clicks.
5. CODE INSTALLATION - turn the radio on, press "SRC" and the radio will ask for the code. Enter the code using the 1, 2, 3 and 4 buttons - confirm it using the 5 button.
  • 82 Answers
    Sniper:
  • 113 Answers
clean the cd player using a cleaner disk.
Good Luck.
neo
Fiat radio code
Hi
Can anyone supply a code for a Blaupunkt IDC-A09 5-Disc CD changer?
Serial: BP910041409139
Other numbers: 815 IDC A09
7 607 769 100
021538
Thanks in advance.
Jul 29, 2013 | Car Audio & Video
Lost CD Changer code! Blaupunkt IDC A09! SN: 9100014675941
hey can i found code for cd changer fiat punto
serial no bp915024323237
produt code 7607769150
blaupunkt-werke gmbh
Sep 28, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09 not recognised
If the unit you replaced it with is exactly the same model as your old one and its the same head unit, then i would check the lead, try wiggling it and seef it recognises it, if not then someones sold you a dodgy cd changer from ebay
Mar 12, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Bluapunkt IDC-A09 Not playing
That is probably a dirty lens problem, try first cleaning the lens.
Feb 28, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 NOT RECOGNISED?
try unplugging both the changer and the head unit, leave it for 10 to 15 mins then plug the head unit in 1st, then the changer.
let me know how you get on
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Not playing!!
hi the A09 has to be married to the head unit, unless your model is the A09 PSA.
Mark
Apr 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
