Question about Samsung PCK520R TV
Yellowish picture everything else is good
Glary yellowish picture samsung 52'' tv pck520r
  • battlaxe7140 Apr 24, 2009
    yellowish sepia tone,same problem. no adjustment works
    Champion:
  • 205 Answers
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Posted on Jul 09, 2009
My terminal board became loose as a result of moving the tv from one house to another, the cable input is still in tact but when i hook up a dvd player to it and hit tv/video it shows all of the ports as...
you may be able to remove the back cover and see if any connectors are loose or if the board is plugged in(if it plugs in). get a pencil and gently press each of the connectors that have plugs in the to see if they are loose..re-assemble the tv and try it...worse case is circuit board is cracked or solder connections bad
Dec 27, 2010 | Samsung PCK520R TV
THe picture is either yellowish green or yellowish orange. And has squiggly lines thru the picture. What needs replaced?
Tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.Try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Samsung/Akai tvs using the same convergence board.
Nov 06, 2010 | Samsung HCN4226W 42" Rear Projection...
Replaced lamp now yellowish orange status light is flashing
Hi,did you close everything up,make sure door cover is closed.Do you hear clicking noises? If you do it could be an issue with the the ballast that the board that powers the lamp.Make sure fans are running ok,dust them out if they are dirty.Also reset lamp timer by unplugging tv wait 5 min and plug it back again.Good luck and God bless you!
Oct 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mirror shattered and we are looking for another one tv is a 52" samsung model # pck520r
well never fixed this poblem i cant see why you can take the measuments goto a glass factory a mirror is a mirror try that good luck
May 03, 2009 | Samsung PCK520R TV
Color problem with the samsung 46" PCK520R TV
There are a few possible causes for this
-Picture tube has become weak after long useage
-A fault with the automatic degauss circuit could be causing the color problems.
-The color drive circuits may be out of adjustment.
I don't have instructions for you on how to fix this, I would recommend you either buy premium assistance or contact
another expert with long tv experience to possibly get details
on how to correct this problem.
I would recommend you contact your dealer for repairs if you have warranty. If you don't have warranty it may be cheaper to ask around.
Jun 09, 2008 | Samsung PCK5315RX TV
Yellowish green problem
could be picture tube or deguassing coil. Remove any magnets around set including speakers etc. Try turning off and on see if makes a different.
Sep 21, 2007 | Zenith D52WLCD 52" Rear Projection...
Samsung PCJ-522R
hey john if you look into the blue crt it will be very foggy..the coolant in the crt needs changing. you may want to contact a local tv repair person for more advice and coolant changing procedures....john
Sep 01, 2007 | Samsung PCJ522R 52" Rear Projection...
Picture bowed on sides
how badly is it bowed on both sides? if it is too much. ther is a fuse resistor that is gone bad near the coil in the east west section. you need to replace that. if it is not too much..you need to get into the service mode to fix that..good luck
Apr 05, 2007 | Samsung PCK520R TV
Problem with Samsung PCJ522R 52": White is yellowish
It is possible that you may have had a leak in one or more of your CRT coolant chambers, see: Product: Projection TV Bulletin # PJT01-001 Model: PCJ, PCK and HCJ series Bulletin Date: 6/1/01 SUBJECT: CRT Leakage Background: When repairing set for CRT leakage, check if CRT has Expansion Chamber installed. If not, install Expansion Chamber on all 3 CRTs. Production during November 1999 ~ September 2000 will need Expansion Chamber installed. Rear panel will indicate production date. This can also leave a residue on your printed circuit board that would have to be cleaned off to prevent further corrosion and leakage currents. Hope this helps.
Feb 01, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
171 people viewed this question
Henry  Thomas
Henry Thomas
