Question about Timex T609T Clock Radio
Timex T609T CD player stops working
After a few months, the CD player stopped working. It doesn't spin, and it shows "no" in the clock display. I called the company, but they are not exchanging or repairing it. Anybody know a fix? Thanks.
  • aimeeadamek0 Mar 30, 2009
    The same exact thing happened to me. I found that if I unplugged it - it would miraculously "reset" - but even that has since stopped working. I'm on the verge of buying a new radio...I use this at work.
3 Suggested Answers
  • 3 Answers
SOURCE: After a few months, the CD player stopped working.
Each CD Player has a potentiometer to adjust the laser assembly alignment. The T609t CD player has a tiny pot of 2000 Ohms (2K) about 1/8 x 1/8 of an inch on a tiny printed circuit board right under the laser assembly. I tried adjusting its value with no success. The wiper was not making contact with the carbon layer below it. I removed it and soldered in 2 wires of 6 inches to work out of the box. I attached at the end of the 2 wires a small printed circuit board of 1/2 x1/2 inch to solder a new pot of 1000 Ohms in series with 50 Ohms resistor. I started increasing the pot value until about 700 Ohms and immediately the Player showed 01 on the display and started to play IL DIVO songs. Obviously after each new setting of the pot I had to repeat the same routine: Power off, power on, hit Play, see No CD message on the display until I found the right initial value on the pot. I still had to tweek it up toward 750 Ohms because it was skipping a bit of song number 8. It is working fine now.
I taped my mod, tucked it in the box and closed the whole thing until the next time it will go out of alignment.
The pot I am using is bigger (3/8x3/8x1/4) it takes 44 turns of 180 deg to sweep it from 0 to 1000 Ohms. The old pot is swept from 0 to 2000 Ohms in one turn of 120 deg. The 50 Ohms resistor was for safety in case I hit 0 Ohms on the pot. I kept it in the mod in case I want to hook a scope.
Cheers
Peter
Posted on Jan 19, 2010
  • 17 Answers
SOURCE: Need an instruction guide for
Go to the Timex website and look for support. Usually you can find the manuals online, otherwise you can request one through support.
Posted on Oct 18, 2010
Need an instruction guide for Timex T609T
Oct 18, 2010 | Timex T609T Clock Radio
Cheers
Peter
Jan 18, 2010 | Timex T609T Clock Radio
CD player stopped working; nothing happens when I push the "play" button. I don't know where to take it to get it fixed; the repair person I took it to told me I should get an MP3 player!
Most likely faulty lens eye or circuit. YOu can try to clean it with rubbing alcohol and cotton swab, otherwise it will have to be swapped out
Aug 04, 2009 | Timex T600 Clock Radio
Cd player doesn't play.
If you are using a pirated cd or self compiled cd, chances they don't play. try the original cds
Jun 26, 2009 | GE 74801 DUAL ALARM CLOCK RADIO .9" LCD
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
How do i set the time on 1440 T5K085
The instructions that came with my watch didn't work but after playing around with the buttons for a while i final came up with this: Press the mode button for 2 secs. The first display is the alarm. Press mode again and the time shows with the seconds flashing. Use the set button to change seconds, minutes, hours. Use the start/stop button to change from seconds to minutes to hours.This will then take you to change the month, date and day of the week. Mode takes you back to the start (time display). The alarm is changed in the same way.
To change from 12h clock to 24h clock keep the set button pressed (the alarm time is displayed) and press mode, the 'A' will disappear when in 24h mode
When the time is displayed press the start/stop button to show the date.
Not sure how to use the countdown timer or how to stop the alarm yet though!
Aug 13, 2008 | Timex Watches
CD Player stopped working
Probably there is dust on the lens. My CD player (different brand) did the same. I opened the case and cleaned the lens with a photo camera brush (VERY gently). Now it works fine.
If you cannot / do not want to open the device to access the lens, you may want to buy a cleaning CD.
Aug 01, 2008 | Coby CXCD395 Shelf System
Timex T609T Clock Radio Logo
83 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
