Question about Frigidaire FWS833A Top Load Washer
Frigidaire washer machine stop in the middle of the cycle
My washing machine stops in the middle of the perm press cycle & does not spin when on normal wash mode. the lid is also unlock when spinning. kindly advice..
  • melting_fire Mar 03, 2009
    Thanx for the reply. I haven't replaced the Lid switch as yet but i suppose this could be the reason for not working as per instructions.
  • Frigidaire Master
  • 3,361 Answers
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Posted on Feb 28, 2009
We have a frigidaire model atf7000es, it just started when the cycle starts it goes to perm press no matter what starts at 48 goes to 32 stops than goes to 38 starts back to 32 and repeats its self
Hello Ken, thank you for your post!
I understand that your Frigidaire washer is going directly into the perm press cycle no matter which option is selected. I would suggest performing a reset on the washer and you can do that by disconnecting the power from it for at least ten minutes. If the reset does not correct your issue, you may need to have the control panel or a wiring harness replaced. If you need help disassembling your washer I would recommend seeking a professional technician. You can locate a technician by contacting your manufacturer. Hopefully this information is helpful to you. -Matt
Apr 26, 2016 | Frigidaire Washing Machines
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
The spin cycle is not functioning
electronical fault not motor but the controil unit is no working ok ....
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
268 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
