Question about Nokia 9300 Handheld
NOKIA 9300 FORMATING CODE - Nokia 9300 Handheld
  • spiketide Mar 11, 2009
    hi neo....
    i have a 9300 and i get the :not enough memory: close applications: error.... i dialled the code *#7780# but it ain't working...
    i dunno what i'm doing wrong... so.. can u please give the exact procedure to soft format....?
  • manzi Mar 30, 2009
    not enough memory: close applications when i send sms .....
This code is not working
Posted on Mar 11, 2009
    Sniper:
  • 113 Answers
Below are some reset codes for various Series 40, 60 and the new Series 80 Communicator series (Nokia 9300/9500):
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, 12345 and then Yes.
Soft Reset: *#7780#, 12345 and then Yes. (Also works on Nokia S40 phones as a full reset)
*#335738#
*#delset#
This deletes the Email, GPRS, MMS settings that cannot be erased via phone options.
Good Luck!!!
neo
Posted on Feb 28, 2009
Plz can u help me my nokia photo 9300 is not formating in this code *#335738# can u help me
Posted on Apr 30, 2009
3 Suggested Answers
SOURCE: can`t format the memory card on nokia 9300
Go to Office -
select File Manager, File storage, select Memory card
hit Menu,
right arrow to Memory card,
down arrow to 'Format memory card' then Select. Job done
Make sure back is on & sensor depressed.
Peter T.
Posted on Aug 05, 2009
sanoojsiddik
  • 203 Answers
SOURCE: how code format nokia 9300 comunicator
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370# then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Posted on Nov 13, 2010
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
Hi sir, i have problem with nokia 9300,when i start internet there is error display is specific path not fount . i have already received mobile setting
try to format it via thish code
remove sim and memory
and also battery
press ctrl+shift+f+on off swith and insert battery phone ask u format. try thish
if ur fault solve dont forgate thanx
note:u can lose ur data
Feb 14, 2011 | Nokia 9300 Handheld
My nokia 9300 is on offline mode, I'm pressing the switch buttom, it's showing only offline profile is active.?Kindly suggest me what to do???
and also battery
Feb 12, 2011 | Nokia 9300 Smartphone
How code format nokia 9300 comunicator
Nov 09, 2010 | Nokia 9300 Smartphone
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
What is the formet code of nokia 9300
HI,
I have attached a video for your easy understanding how to format you nokia 9300 mobile.
http://www.youtube.com/watch?v=TpyQOFhQEkA
Thank You
Aug 13, 2010 | Nokia 9300 Smartphone
Nokia 9300 communicater fomet code
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Format it
Is there any code to format 9300 handset?
hello,
you can reset your handset by any one of the following ways:
Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, and then it asks for your security code (by default it is 12345) and then Yes.
Good Luck!!!
Jan 16, 2009 | Nokia 9300 Handheld
Re-format
apparently this works
* Press and hold the following 3 keys until a Format Message is displayed:
CRTL + Shift + F
Apr 06, 2008 | Nokia 9300 Smartphone
Formatting nokia 9300 comunicator
Feb 23, 2008 | Nokia 9300 Smartphone
Nokia 9300 Handheld Logo
1,293 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
