Question about Blaupunkt IDC-A09 5-Disc CD Changer
Bluapunkt IDC-A09 Not playing
Hi have plugged in my IDC A09 for my fiat punto and my radio unit recognises the cd changer and it loads and unloads electronically but wont play any of my cds.
can you please help me
Lance
  • afroman73 Feb 28, 2009
    hi have plugged in my blaupunkt IDC A09 into my fiat punto and my radio unit recognises the cd changer and it loads and unloads electronically but wont play any of my cd's. i read in another post that its a case of marring the unit and the changer together but dont know how this is done can you help me with a step-by-step quide on how to solve this problem. Lance
  • afroman73 Mar 03, 2009
    Thanks for the help guy's much appreciated
    regards Lance
    Genius:
  • 1,011 Answers
Sir,
1. REMOVAL OF UPPER GLOVEBOX TRIM - remove the two Torx Screws (T25 from what i remember) on the upper part of the upper glovebox trim. With these removed, pull the trim out - it is "locked" in at the bottom, so it might be slighlty hard to remove. Just ease it out from the bottom once the top is loose.
2. INSTALLATION OF CABLE - Remove the radio (2 standard radio keys), and plug in the cable (check your Radio instruction book - it's in there somewhere). Look through the hole in the upper glovebox - you can push it through to that compartment. Once you have, put the radio back in.
3. INSTALLATION OF NEW UPPER GLOVEBOX TRIM - you need a new upper glovebox trim, with a ISO radio hole. Get one from Fiat. When you get the autochanger, take the metal cage out, and place it in the new trim (it clicks into place). Push the new trim back into the glovebox, remembering to pull the cable out. Make sure it sits flush at the bottom before you screw it back, so the glovebox lid will line-up correctly again.
4. INSTALLATION OF CD AUTOCHANGER - plug in the cable, and slot into the socket! I tried putting the fixing pads Blaupunkt suggested, but Fiat told me they are not needed - I agree, as the CD changer wont fit, and it nearly broke the unit!. Push the unit in until it clicks.
5. CODE INSTALLATION - turn the radio on, press "SRC" and the radio will ask for the code. Enter the code using the 1, 2, 3 and 4 buttons - confirm it using the 5 button.
Posted on Feb 28, 2009
    Sniper:
  • 113 Answers
Yes i can help you. please wait for your first forum question, why you post it on another forum.
  • nenotech_neo Feb 28, 2009
    hi ginko, please follow the another link.
    http://www.fixya.com/support/t1724345-pl...
    here is some more detail about the question.
    Thanks
  • 19,396 Answers
That is probably a dirty lens problem, try first cleaning the lens.
  • 1 more comment
  • Ginko
    Ginko Feb 28, 2009
    When a CD unit does not read any CD, then the first suspect is always a problem with laser lens.
    The unit will try reading CD , but all that you hear is whirring and clicking noise as the lens cannot read CD first track.
    Try using a cleaner CD to clean the lens, and if you can reach the CD lens try blowing some canned air on it.
    If the problem is not the lens , then it may be a bad data cable or a disturbance on data cable.
    The data cable is the cable that connects to CD changer.
    Check the data cable connections.
    Test the CD changer with engine off to exclude disturbance.
    The data cable may be tested with a special device, but for that you need to go to an authorized repairer.
  • Ginko
    Ginko Feb 28, 2009
    What you are talking about , when you talk about marriage between unit is the encoding decoding setup.
    You find instructions on how to do that here.
  • Ginko
    Ginko Mar 02, 2009
    Hi there, since we tried to help, and you have had your fee refunded, I will be grateful if you can change the negative rating given.
    Many thanks.
Fiat radio code
Hi
Can anyone supply a code for a Blaupunkt IDC-A09 5-Disc CD changer?
Serial: BP910041409139
Other numbers: 815 IDC A09
7 607 769 100
021538
Thanks in advance.
Jul 29, 2013 | Car Audio & Video
I have purchased a Fiat Punto, I need the Radio Code, seller does not have it, BP1430X0005062 , PART NO 7612001433. CAN YOU HELP. THANKS
am soy dont know wat u pepole want?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
Feb 06, 2013 | Blaupunkt IDC-A09 5-Disc CD Changer
Lost CD Changer code! Blaupunkt IDC A09! SN: 9100014675941
hey can i found code for cd changer fiat punto
serial no bp915024323237
produt code 7607769150
blaupunkt-werke gmbh
Sep 28, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Fiat cd changer wont keep its code inthe memory
The radio requires TWO battery feeds.
One is a permanent battery feeding the code and station memory
The other is the main one  via the Ignition Switch
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Fiat punto mp3 or not?
I cant say about the mp3 disk but the aux is auxilary and the leads are located behind the stereo system yellow and red, you can buy the removal pins from most motor factors.
Apr 17, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09 not recognised
If the unit you replaced it with is exactly the same model as your old one and its the same head unit, then i would check the lead, try wiggling it and seef it recognises it, if not then someones sold you a dodgy cd changer from ebay
Mar 12, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 NOT RECOGNISED?
try unplugging both the changer and the head unit, leave it for 10 to 15 mins then plug the head unit in 1st, then the changer.
let me know how you get on
Mark
www.blueice-electronics.co.uk
Nov 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Not playing!!
hi the A09 has to be married to the head unit, unless your model is the A09 PSA.
Mark
Apr 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Bluapunkt CDC IDC A09
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Feb 29, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
702 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
