Question about Compaq Computers & Internet
Screen display is not coming
After switching it on wall paper is coming.then it is disappearing and then a screen displaying welcome and then the screen with the users is coming.when we press our user icon , its saying logging off and te sceen decktop s not coming
First disconnect all the power cables from the CPU. then open the cabinet and locate the lithium ion battery on the motherboard. pull out the battery and then short the pins (both the pins) with the help of a screw driver for 5 - 10 seconds. then replace the battery and close the cabinet and then connect the power cables and swiitch on the power. after that press F1 or DEL (as the case may be) for fetching the BIOS set up page and then set the Boot Configuration accordingly. then save and exit. i hope it will work. please dont forget to reset the date and time on the monitor.
Posted on Feb 28, 2009
Why does my tablet when I switch it on there is no image, although it is on?
Go into the display menu and select another wall paper. If that doesn't work do a factory reset to restore function.
Sep 07, 2016 | Tablets & eReaders
Display PPPPPPPP only
The machine is telling you that it cannot detect the paper. Replace the paper roll
Mar 25, 2014 | Sharp ER-A450S Cash Register
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
My Nokia cell 7210 bought in 2008. It was in perfect condition till yester night. Battery charged in full and unplugged when displayed. Today morning while searching in sent items of messages, the...
try to replace battery...check if the battery socket is losing or have allowance..insert a rubber pad to fit the battery socket wether its moving or not...try to clean the battery terminal,maybe some curosion or dirt exist.
May 29, 2011 | Nokia Cell Phones
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Maintenance request 0040 is showing on our Epson stylus pro 7800. Could you please reply with the solution? Thanks.
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Oct 27, 2010 | Epson Stylus Pro 7800 InkJet Printer
How do i get the o2-uk logo off the screen of my samsung jet
if it's a wall paper,  you may change it through, settings.. from your phone, press menu. select settings select display and light from your display menu, select wallpaper from your wall paper menu, select and browse for images and photos from your phone once you select images, press set as wall paper press save and exit the settings...
regards....
Mar 29, 2010 | Samsung Jet S8000 Cell Phone
Wall paper is displayed however not the PPT or Icons
You need to configure your video card.
I'm assuming this is a laptop you are working with. Go into the video card properties, and make sure the VGA port that drives the projector is not set to extend your Windows desktop.
From your desktop, right-click and choose the "properties" option.
In the Display Properties window that comes up, select the far-right tab "Settings".
See the rectangles labelled 1 & 2? Click on the rectangle with the 2, and then look down near the bottom where you'll see a checkbox with "Extend my Windows desktop to this monitor."
Make sure this box is not checked (it most likely is right now, and that's the source of your problem).
Mar 29, 2009 | Epson Office Equipment & Supplies
Grand WEGA continuously displays SATELLITE in upper left
Please press " i " button on TV remote so on-screen display will disappear.
Mar 10, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen disappear
Losse cable, either in back of LCD panel (beneath top cover) or loose at video card connector (beneath) power switch cover/ assembly.
Jan 14, 2008 | IBM ThinkPad R50e Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
