Question about Gem Sound GemSound GEQ-256 Home Equalizer
I have purchased karaoke dj system gemni cdx-2500g dual 2u cd
I have a equalizervocopro DA-1055 700 watt amp and 450 watts speakers trying to connect to the system . The sound is not right it has no bass What do I need to do?
2 Suggested Answers
  • 4234 Answers
SOURCE: Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Posted on Sep 24, 2008
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
The power off
need much more info to help. $300 amplifier made in china with stamped surface mount components. Have fuse and transformer thermal cutout tested, if these work then throw the amp out as it is darn near impossible to repair these things.
Mar 22, 2014 | Technical Pro Ax3000 3000 Watt 2 Channel...
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
Hay i just brought da sub on its own and dont no wat a good size amp and power needed to make dat bumpn bumpn feel...and how to connect it all up plezzzz.... fnx DJ KINGXL out
buy a bridged amp with half the power of your sub (ie 1200 watt sub use a 600 watt amp) this will stop distortion at high volume get in touch when you have the amp and i'll go through how to wire it .
Aug 20, 2009 | MA Audio MA 1200XL Car Subwoofer
What buttons do i push for a music cd or anything to play?
I can send you a manual if needed. kb3xy@krbenson.com
Dec 12, 2008 | JVC XL-SV22 CD Player
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
Gem Sound GemSound GEQ-256 Home Equalizer Logo
60 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
Ernest
Ernest
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
