Question about Gigabyte GA-8INXP Motherboard
Boot-Problem After several years of work the PC makes some noise that i thought the HDD was defect. I did not regard this so after a while the PC decided not to boot any longer. I changed the Memory and the PC bootet until the the monitor freezed with the message : press F1 to go on or ? to enter bios. Pressing F1 does not work and so did bios. After this event the monitor showed no further signs. So i changed the battery of the board - without any effect. I payed over 200 Euro for this board - and i am not willing to give up hope that one can help me with this problem. So if you have the solution tell me and be shure i am gratefull.
  • macintosch Mar 01, 2009
    @steve
    Thank you for your hint!. Yesterday i tried another mainboard (FSC D1875) an the drives worked well. The only sign that there could be a problem with the HDD`s was a double beep when i started first. A the second start the PC booted without trouble. So i believe there must be a problem with the Gigabyte-Board whatever it is.
    If anyone knows what else it could be .... please tell me!
  • 32 Answers
Your harddrive is defetive..its not finding what it needs to make sure hardrive is number one for boot in your bios..steve
Posted on Feb 28, 2009
My asusk55v lap is stuck with boot screen ,but some time it work normally and when it goes few minutes againg stuck !
defect hdd. Download a hdd-testprogram according to your hdd-manufacturer. You can easily find out by entering bios, press F2 at boot up.
Aug 27, 2013 | ASUS Computers & Internet
Laptop can not boot,noisy hdd
Hello, welcome to Fixya!
It is obvious that the hdd of your laptop is defective. The HDD has some bad sectors which is most likely beyond repairs.
You need to replace the HDD of your laptop because the noise you are hearing is an indication that the HDD is defective.
I hope the above information is clear. If not clear, please let me know.
Regards.
Nov 16, 2011 | Computers & Internet
When i put my samsung g3 station 2 TB on my pc, my pc will not boot.. When i look it up in de BIOS the C:\ is not available.. that why it cant boot.. it does not see the normal HDD. how can i solf this...
My desktop has a 6 year-old motherboard which will not start up if the external USB HDD is turned on. So I have to make sure the HDD is off before turning on the PC in the morning. After it starts booting I can turn on the HDD and everything works fine.
Does your machine work this way?
Mar 12, 2011 | Samsung G3 Station 1.5TB USB 2.0 External...
Beeps 2 times & a warbling noise when trying to boot up - unplugging power lead & pressing ON/Off button & reconnecting power lead starts up OK - but it can be OK for several days & th
By warble, do you mean a high pitch non stop noise? If so... I think I went through that bout 2 months ago, it was a easy fix. Ifr it is the same problem
May 29, 2009 | HP Vectra VL420 Intel Desktop PC - Intel...
Error message Non system disk error replace and strike any key wh
Hi !
This error means either there is no disk (or disconnected/wrong connected) or your HDD is gone (which I don't believe) !
I can't find a reason why you pulled out your HDD when it was (I assume) working good before ?!?
Anyway, . . .now, please check carefully the connectors - both sides, to the HDD and to the Board(if any), if they are properly fit!
It is an IDE disk and there are two groups pins on the HDD. Check the pins if they are all going to plastic male connector (and then to the board.
A group of 4 or 6 pins on HDD should not be connected. There is one pin missing in (about) middle of the second row of pins - it is o.k.
Put your ear close on the chasis of laptop and find if there is a spinning noise when you turn your laptop on.
If there you can hear noise, then check in BIOS if your HDD exists.
If not, try to check it on another Laptop/PC.
Regards.
Apr 22, 2009 | Compaq Evo N800C Notebook
Unable to boot os after power supply change
I would make sure you connected the Power to the main switch correctly it is usually a 3 wire connect, check all connections on the HDD, motherboard, and CD's. also check the WATs rating on your old power supply against the WATs on the new power supply, if the new one is less that is probably your issue.
PLZkeep me posted.
Apr 01, 2009 | Computers & Internet
IBM thinkpad will not boot past Windows Xp screen.
sounds like the hdd is faulty, google drive fitness test and download it from the hitachy's website works for any hdd, burn it as bootable image and boot the mach from the image and run the test look out for the error code anything other than 0x00 means the hdd is faulty
Jan 28, 2009 | IBM ThinkPad T41 Notebook
Dear Sir, my problem is as follows when i switch on my PC it says boot disk failure. so i checked the BIOS. I saw there is no Hard disk name in the list though i have attached the HDD perfectly. I have...
hi,
there are many chances of HDD boot sector gone dam.
do some work to know whats wrong--
boot your computer using another HDD and make your old HDD as a slave disk; if the old HDD is serched as a slave thats mean your HDD is fine.
for any question ask me.
Thanks for your question
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
PC won't boot
Have you tried reformatting on the broken machine?
Oct 22, 2007 | Dell Dimension 8100 PC Desktop
Gigabyte GA-8INXP Motherboard Logo
62 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
