Question about Samsung ML 1610 Laser Printer
Samsung ml-1610 pulls in paper only half way then stops and red light turns on. I tried to restart printer, replace papers, put only one page, put many pages... nothing works.
  • wsoft123 Feb 28, 2009
    "nd open rear side of door of printer" - where is this rear side of door, and how to open it?
    Thanks!
  • Anonymous Mar 31, 2014
    The top light bar become red when I put on the machine and it does'nt work at all.
    the cratridge is OK and the door is well closed.
Reinstall driver, turn off and on again. No official solution, though. It just worked for me.
Posted on Mar 19, 2009
  • 59 Answers
Dear,
pl swithch of your printer and remove printer cartridge from printer. and open rear side of door of printer and remove your page gently
after remove page see carefully paper is jamed or not.
after swithch on.
check with print.
Posted on Feb 28, 2009
Hi my samsung ml-1610 mono laser printer shows red light contineously i dont know what the problem is can u help me please
see, you have inserted the paper well. if not solved, your catridge have low ink or empty. so bring a new catridge or if you can, refill the catridge. 1610 catridge can be easily refilled.
Aug 27, 2011 | Samsung ML 1610 Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Online/error showing red light, could it be a toner problem ?
it could well be a toner out problem, put paper in the tray and press the button for a second or two, if the light starts flashing and the printer prints a configuration page then its a certainty, also the config page will tell you if the toner is out
Nov 07, 2009 | Samsung ML 1610 Laser Printer
Samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
Oct 08, 2009 | Samsung ML-1640 Monochrome Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Online/Error
this could probably caused by interrupted spooled jobs that was sent earlier, as i assumed, try pressing the cancel button on the printer itself, or from your pc cancel all documents.
if you cant recover still reset the printer once again and put some paper to finish the pending job that was qued earlier
Jul 25, 2008 | Samsung ML 1610 Laser Printer
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
410 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
