Question about Hotpoint WMA74 Front Load Washer
Hi, I have a hotpoint aquarius mwa30, the door lock light flashes and/or not at all. I bought a new door interlock but it still does the same but if i link out the 2 wires in white then it tells the washer the door is locked and the washer does a full wash , can anyone help please . Richard
    Sniper:
  • 100 Answers
The spring may have gone in the latch on the door.
close the door and push the handle part by hand to move the latch into the lock more firmly.
to replace the spring or handle assembly remove the screws from the back of the door and prise the front off.
Posted on Feb 28, 2009
SOURCE:
HOTPOIT AQUARIUS DOOR LOCK LIGHT FLASHERS
Faulty door interlock easy to fit cost parts about £15
Dec 11, 2014 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
How to get access to door interlock mechanism?
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Dec 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
195 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
