Question about HTC P4350 Smartphone
Phone doesn't ring for an incoming call
My HTC touch has a problem.When someone is tryin to cal me they hav my phone ringing in their handsets but nothin actually shows up on my mobile.No ring, no call, but later shows an orange flash light as in like a missed call notification.untill then its only idle. i have the same problem wit my htc p4350.....when someone call to my phone they have their phone ringing but nothin shows up on my phone..and some times i even donot get sms too
    President:
  • 1,223 Answers
Pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Posted on Feb 28, 2009
Handsets don't ring?
I assumed you are talking about your wireless phone. Are you worried about handset ringing or the incoming call ring? 1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone. Hope this helps. Best regards.
Sep 01, 2015 | Lands Phones
How do i change the ringtone callers hear when they contact my htc wildfire
Thanks for visiting FixYa!
In most cases, the ring tone callers hear (incoming ring tone) is controlled by your cellular service provider.
Try this first: (On the Internet) Sign-in to your cellular account. On your account page, look for a link that directs you to your incoming ring tones (or similar). There, you can change your incoming ring tone.
If you're unable to do that, contact your cellular provider's Customer Support. They can assist you in changing your incoming ring tone.
May 30, 2011 | HTC Wildfire Cell Phone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
You may have already done this, but the first step is to check your various settings.
Go to Start > System Tools > Settings
First, go to the "Profiles" menu and make sure your phone is NOT in Silent mode.
Then, if your phone still isn't ringing, go to the "Sound" menu and make sure your Ring tone and various other sounds are set appropriately.
Finally, you should try turning off and on your phone and seeing if this corrects the problem.
If none of these tasks work, there may be a hardware issue with your phone and you should bring it to your carrier's local store and ask them to fix or replace it.
Aug 04, 2008 | Samsung SGH-D500 Cellular Phone
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
HTC P4350 Smartphone Logo
251 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
