Question about Bosch MCM5200 Food Processor
Looking for parts for mcm5000 or 5200
I'm looking for a main blade (gah) and dough hook for an mcm5200/5000. Will pay a fair amount. Please email suffisance AT gmail.
  • 137 Answers
My pie dough comes out too soft and wet, what am I doing wrong?
If you feel dough being to wet, just add more flour a table spoon at the time. The dough shouldn't be too sticky. When making dough you can't always be followed exactly what the recipe says. Unless you're in a controlled environment like a baker has. Humidity and temperature play a big role. If it's to wet add more flour, to dry add a bit more water. but adjust only with tablespoon amounts.
Jan 08, 2015 | Food Processors
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
Magimix blade is stuck
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Jun 28, 2009 | Magimix 5100 Cuisine Systeme Food...
Am I missing a part
I overlooked this too. Set into the foam packing material is a stem made just for the shredding disk. It's about 4" long and also has a hex shaft. This hex is just slightly smaller than the hex on the other shaft the drives the blades. The dough hook - Remove the blade assembly and put the dough hook in its place.
Apr 08, 2009 | Black & Decker Food Processors
Blade holding disc for Breville Food Processor Model No. FP7/FP8 Replacement required. Phone numbers required for contact.
Hi. I'm a Breville Service Centre.
No new parts for FP7 or FP8 are available, your best bet is to check out garage sales or you local Salvos/St Vinnies etc as people may sell their odd pieces once their motor dies. Which is rare because they were good machines!
Mar 18, 2009 | Food Processors
Motor fails to operate - very hit and miss
Make sure you are using the dough blade for dough instead of the regular blade - dough will cause the regular blade/assembly to gum up. This is actually a VERY high quality unit w/ a 20-year motor warranty. I would see if you get better results with the dough blade. Don't give up on it yet.
Dec 14, 2008 | Cuisinart Limited Edition Metal MP14 Food...
Dough hook stuck
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Sep 05, 2008 | Magimix 5100 Cuisine Systeme Food...
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Making Dough
Yes, it is the S-blade. I can't find my manual either and I have been trying to figure out how to get it onto the shaft!! The Hamilton Beach website says it should slip down the shaft once the bowl is attached, but I have a white piece on top of the metal I can not remove and the s-blade will not slip over it.
Dec 03, 2007 | Hamilton Beach Chefprep 70700 Food...
Bosch MCM5200 Food Processor Logo
116 people viewed this question
Top Bosch Food Processors Experts
Are you a Bosch Food Processor Expert? Answer questions, earn points and help others
