Question about Canon imageCLASS® MF6550 Laser Printer
PAPER JAM WITH THE CANON IMAGECLASS 6550 Laser PRINTER
How do I solve this problem? The paper gets stuck in the feeder. It is impossible to remove
    Scholar:
  • 136 Answers
Chances are theirs either something that got lefted in the assembly afterward like a sticker,I would have the paper tires replaced, to prevent future problems .
Posted on Jul 24, 2009
Canon printer MF 8080 cw will not reset after a paper jam
Hello, If the printer will not reset then you still have a piece of paper stuck somewhere in the paper path. Did you power the printer down and back up? Here is manual.
Canon imageCLASS MF4150 Manual
Sep 30, 2014 | Canon imageCLASS MF4150 All-In-One Laser...
Paper Jam on the Canon Imageclass MF6530
Make sure that there aren't any tiny pieces of paper stuck in any of the rollers or gears. This can cause that as well.
Dec 10, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
Paper jam stil occur
Hi
Turn the printer off and on.This is known to automatically remove any stuck paper by pushing them out.
Look through the paper paths and remove any stuck papers.
Load less papers through the paper input tray.
Feb 20, 2012 | Canon ImageClass MF4350d All-In-One Laser...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Papaer jam
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon service provider.
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Thanks
Concerned: Angel Bird
Mar 31, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Sir my printer is canon mf 4320d sir it appears paper jam on display but i open rear and front cover but any paper is not found jam please help
I had the same issue, Turned out to be a tiny scrap of paper inside the fuser (the thing in the back behind the "caution hot" sticker. It was nearly impossible to see. I removed the screws on the fuser cover (to loosen, it wouldn't come off), then lowered the top lip enough to see the bright orange fuser roller. The paper scrap was stuck on the right side.
Sep 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Says paper jam but can't find any paper anywhere
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Paper Feeder
if it's causing a jam then you're going to have to take it apart
Apr 18, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS® MF6550 Laser Printer Logo
332 people viewed this question
old marine
old marine
