Question about 3M MP 7760 Multimedia Projector
What is the life of projector bulb. the image are not clear.
  • 1,073 Answers
The normal lifetime for almost all lamps for projectors are 2500-3000 hours in EKO-mode and about 1500-2000 hours in normal-mode
You will notice that the lamp is goint out of time by the light of it, the image will be darker and darker untill the lamp dies/explodes.
If your image isen clear you have to clean your projector, and by that i mean a realy good clean inside it. If you arent sure how to do it i sugest you leave it to a repairshop to do the work, its not expensive and they will do it properly.
Btw, if you ned to buy a new lamp, let me know, i know where you can order a new lamp to realy good price.
Good luck
Posted on Feb 28, 2009
Image/power issues
A lot of projector lamps / bulbs only have 2000hrs of expected life. that's about a year if you use it to watch TV. Do you have a backup to try out ?
Oct 25, 2013 | Canon XEED SX50 Multimedia Projector
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Hi i replaced my bulb for Sony VPLBW5 now i am not getting a clear picture anymore, its very distorted and something seems very wrong
It's very unlikely that this is a due to a faulty bulb.
It's possible that there is a fault with the projector which existed before you relamped it, (i don't know the exact circumstances) but you could try the following steps
1) If the old lamps still works, remove the new one and replace it with the old one. fire the projector up and see what happens. If nothing happens replace the new one again, making sure you don't touch any glass parts (as it can shorten lamp life) or any other internal parts.
2) Turn the projector on and check the image with different picture sources and cables to rule out a fault there. Is the image distorted while the projectors warms up and displays the startup screen? If the image looks correct the problems is likely to be outwith the projector. If the startup image is distorted then the problem is likely to be with the projector.
You should ensure that the lens is free from obstructions. It won't make much difference in most instances but you could clean it with a soft cloth, taking care not to damage it.
Hopefully these steps will help you fix the problem.
Feb 18, 2011 | Sony VPLBW5 LCD Projector
Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
May 05, 2010 | Planar PR3010 DLP Projector
IXD 420U projector takes a long time to project and has pink ima
If possible, try to replace the VGA cable between the projector and the computer. A bent or broken pin, or a damaged wire, can prevent the blue or green (or both) portions of the picture from being displayed. The result is a reddish/pinkish picture.
As for the long time to project an image, this could be an extended warm-up time. How old is the bulb in the projector? Does the projector have an option to display the hours used and/or remaining on the bulb? Bulbs do have a finite life, and when they near the end of their service life, they can become more difficult to start.
Hope this helps!
Feb 22, 2010 | Office Equipment & Supplies
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Dec 09, 2009 | Epson POWERLITE 400W Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Jan 18, 2008 | Sanyo PLC XU50 Multimedia Projector
Projection tv lamps
All fillament based lights will dim as they age. Some of the newer/better types it will be unnoticible.  If you are losing image quality or brightness you may have a bulb that is nearing the end of it's life cycle.  A glance at you owners manual or the manufactor's website should give you an indication of the expected life of your bulb.  Also most of the projector made in the past few years have a counter that tallies the amount of hours your bulb has been on.  A more likely culprit is probably dust accumilation somewhere inside your projector. Most projectors have filters these days and need to cleaned at certain intervals and in certains ways.  Not cleaning these filters can cause heat build up that can increase operating temps and shorten the life of your bulb and or projector.  Or sometimes jsut fail and cause a dramatic decrease in image quality.  Again these things are vendor/model specific so you will want to check with them about your particular model. Hope this helps.
Nov 24, 2007 | Panasonic PT-51HX41 51" Rear Projection...
3M MP 7760 Multimedia Projector Logo
117 people viewed this question
Top 3M Office Equipment & Supplies Experts
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
