Question about Whirlpool Refrigerators
Whirlpool side by side middle wall gets extremly hot
  • 410 Answers
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Posted on Feb 28, 2009
Whirlpool model et18tk and the side of the fridge gets hot? It it junk?
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
Aug 15, 2016 | Whirlpool Refrigerators
It's extremely hot around the door frame of the refrigertor mainly the middle strip. Everything else is fine.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
Sep 10, 2011 | Kenmore Side by Side Refrigerator
My whirlpool reftrigertor side by side, fridge side is hot and the seals are extremely hot. I just bought it today at a tag sale, it is only a year oldm, what can the problem be?
If the cooling is OK specially in the freezer and the fridge, then you need not have to worry on much. If there is no cooling then the unit must be checked for failure in the sealed unit.
However you can select a NORMAL thermostat setting for the fridge /.freezer , set it lower than the present settings. Also check and see if the unit had the panels removed, if so the insulation of the heat exchange coils could have come off and it might be heating the side metal wall of the fridge.
The heating of the coil is quite normal as due to the heat exchange needed for the cooling.
Jul 28, 2011 | Whirlpool Refrigerators
Interior wall of unit gets extremely hot
If you are talking about the wall that runs between the freezer and the fridge where the door gaskets actually touch. The answer is no. It should be warm though.
What can cause this is the fan that is located at the rear not operating or dirty coils under there. Check the fan it should be operating when the unit is in the cool cycle, if it is not then it will need to be replaced. And clean the coils. This will help.
May 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool side-by-side is getting hot on strip between doors but everything seems to be working fine. Is there a solution? What if it becomes extremely hot??
It will not become extremely hot. It is heated by a thing called a mullion heater. It warms the area so it doesn't sweat and mold in the summertime. It is perfectly normal.
May 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Side by side refrigerator by whirlpool
try vaccumming under your frig coils, and pull away from the wall and clean under there too. i would check to see if the fan behind the unit is spinnig( its suppused to cool the compressor) if its not youll need to replace that.a pretty common problem easily fixed
Oct 25, 2008 | Whirlpool Refrigerators
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
102 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
