Hello, i am trying to a simple project on grid computing, means in a LAN network if i am wish to execute a program or a task it should divide the task into number of modules and distribute modules to other process in the LAN one module for each process and get back the result of program and should display it to end user. Where the execution time is low when compared with the execution time of a program is executed in a single system without LAN implementation. Do you have any java code for the above implementation Thank u
  • Anonymous Feb 28, 2009
    عايز اعرف كل حاجة عن نظام التشغيل
    Problem Solver:
  • 16 Answers
Try CC+ code....
this is the site>>> http://en.pudn.com/downloads3/sourcecode/java/detail11213_en.html
Posted on Feb 28, 2009
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
No matter if secure or not will not connecet to wifi
Hope this helps
Nov 19, 2012 | Sony VAIO VGN-N325E Notebook
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Virus
A program or piece of code that is loaded onto your computer without your knowledge and runs against your wishes. Viruses can also replicate themselves. All computer viruses are manmade. A simple virus that can make a copy of it over and over again is relatively easy to produce. Even such a simple virus is dangerous because it will quickly use all available memory and bring the system to a halt. An even more dangerous type of virus is one capable of transmitting itself across networks and bypassing security systems.
Since 1987, when a virus infected ARPANET, a large network used by the Defense Department and many universities, many antivirus programs have become available. These programs periodically check your computer system for the best-known types of viruses.
Some people distinguish between general viruses and worms. A worm is a special type of virus that can replicate it and use memory, but cannot attach it to other programs.
Or
A computer virus is a computer program that can copy itself[1] and infect a computer. The term "virus" is also commonly but erroneously used to refer to other types of malware, including but not limited to adware and spyware programs that do not have the reproductive ability. A true virus can spread from one computer to another (in some form of executable code) when its host is taken to the target computer; for instance because a user sent it over a network or the Internet, or carried it on a removable medium such as a floppy disk, CD, DVD, or USB drive.
May 08, 2011 | Computers & Internet
Virus
Or
May 06, 2011 | Computers & Internet
I need a network interface card adapter driver for
On a computer with Internet, goto this link
Scroll halfway down and click on "Network."
Click on the Download button on 3Comm Driver.
Download the driver and save it onto a USB or Pen drive.
Place the USB drive into the USB port of your Optiplex.
Goto your USB drive from My Computer and double click on the executable that has been downloaded.
This will install the network drivers you need.
Hope this helps,
BReady
Mar 27, 2010 | Dell Optiplex GX260 Desktop PC - Intel P4...
Bluetooth not working
Some more details on when and how this problem developed would be helpful in offering solutions.
When would the lan/blue tooth devices show up in hardrives list?
They are usually in the task bar or network connections.
If so open the network connections from either the task bar- which in your case may not be possible as it sounds that you can not see any lan/wlan icons there- or from start- control panel -network connections and see if there are any lan/wlan/1394 etc listed there but disabled. enable them and try. You will need to usually check the properties box of each to show up on task bar and or if connectivity is present or not. You could also check your computer properties, device manager and see if any devices especially network adapters or other devices listed with yellow warnings and fix them individually.
Hope this helps
Dec 13, 2008 | Compaq Presario Notebook
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
