Question about ASUS K8V-MX Motherboard
My system doesnt boot from the PATA drive
Ive got a Pentium 4 ,2.66 and the D865 Intel Motherboard.The BIOS detects the Harddisk but IM not aable to boot from it.Ive tried all the possible jumper settings and in between the CD/DVD and HD stopped working.Right now that parts oK but I still cant boot.The partition was recently loaded with LINUX.Appreciate all help.Thanks in advance
  • terraleogoin Feb 28, 2009
    Hi HiddenShadow,Ive tried all the obvious including tampering with the Jumper.Forgot to tell ya the HD is a PATA.Right now its on Cable select.Initially for two days ,there was no issue but now it doesnt boot.Ok so some Boot file mght have got corrupted right?So I reloaded Linux .I still cant boot.I tried Linux rescue method and was able to navigate to the Desktop through the single shell.Beats me why,the stupid disk doesnt boot.Three days behind this crazy scenario
    Scholar:
  • 93 Answers
Sort of obvious (judging by the stuff you tried) but, Did you try going into the BIOS setup and making sure the hard disk is the first boot device? (if its lower than something else, say a windows hard disk, it'll load windows instead, etc.) If not something is wrong with your linux boot file, and the BIOS can't read/understand it, try reloading linux onto the hard disk.
Posted on Feb 28, 2009
I have replaced the Motherboard with 865GV and the bios detect the harddisk but at the time of installion of XP only 7 GB of space is being but my harddisk is of 80GB could you explain to resolve this...
You have other information on the Harddrive as well as the info you are trying to install. If you have no data you wish to save then just format the drive before you install the OS.
Feb 17, 2013 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My pc400 will not detect hard drive while in clean window install mode. All primary and secondary are set to auto detect. Boot sequence set to cd while installing from cd rom
You can change the pata cable ,if you have a spare.or fit the cable again.
Follow the link.set for boot priority.
http://www.windowsreinstall.com/articles/bios/
Phoenix BIOS setup and help
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Or you can setup bios "load fail save default"na d pers F10>hit
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
What Cpu fit a p5kpl-c and the best to buy.
This is older type of motherboard, made by Asus and supporting Intel Pentium 4, 775pin processor (LGA775). It will support DDR2 to the value of 4GB, it will support 64bit operating system. it have single PATA port, SATA is present but no RAID configuration.
This motherboard requires PCI video card, there is noAGP port and no build in graphics. System is based on Intel G31 Express chipset.
Theoreticaly this motherboard should accept all Intel Pentium for 775 pin processors, albeit early production may need BIOS flush with latest BIOS.
List of processors accepted:
Intel Pentium 4, Intel Pentium D, Intel Pentium Core 2 Duo, Intel Pentium Core 2 Extreme and Intel Pentium Core 2 Quad.
If you need more information or drivers for this particular board, please visit this site adn select exact model:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Do not hesitate to leave feedback how did you go with this advice :-)
Aug 17, 2010 | Computers & Internet
Boot failuer and cmos error and not detect by bios
reseat your pata hard drive, take out the power cable on your system tower, press and hold the power button for more than 15 seconds and then take out the connections on the hard drive and put them back in and then using cmos setup to default values and now try to start your system and see if your hard drive is detected.
if not
swap the power connector with some other free power connector, and try if this also not work
swap your pata cable with another pata cable and if this also doesn't work
either your hard drive or your motherboard is bad.
If You think my solution was helpfull please do rate me
Regards
Ltoso
Jul 23, 2009 | Gateway Essential 400 PC Desktop
Boot failure
Check the connectors running to your hard disk to make sure they are firmly connected. Also check the data cable to the motherboard. Reboot the computer and enter BIOS. Check that your hard drive is being detected properly. If it is not, the drive is shot and needs to be replaced.
May 29, 2009 | Intel Pentium III , 900 MHz Processor
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
PATA Harddisk connection
Hi Murtazasoni, if you have the manual for K8V-MX motherboard you shouldn't have any troubles. You can download it from this link, Win XP; http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
The IDE data ribbon only connects to the PATA drive & motherboard in one direction. Please see the top of page 1-22 for instructions. Most data ribbons for IDE drives have three connectors. The connector farthest from the other two connectors (Two connectors very close to each other), is plugged directly to the motherboard as shown & explained on the top of page 1-22.
If you are only connecting 1 PATA drive to the data ribbon, connect it to the last connector on the ribbon, leaving the next connector for another PATA drive.
Setting the jumper on a PATA drive. Every hard disk drive has a large white sticker on it. This sticker includes information about the drive. Things like the model number of the drive. There is also information regarding how the drive is to be set. Example: if the drive is to be the only drive in the system its jumper should be set to (Master drive only). If there is another PATA drive in the system connected to the same ribbon cable than change the jumper on the drive to, (Master with a Slave). The second PATA drive's jumper must be set to, (Slave). Connect the power cable to the PATA drive ['s]. Re-check all connectors (internally) before closing the case. Boot the system & press the Delete key on the keyboard every two seconds until the main bios menu opens. Open your manual to the top of page 2-7. Here you'll learn how to move about while in the bios. At the main menu you should see your PATA drive. Listed to the right of Primary IDE Master you should see the model number of the PATA drive listed. If not than the drive was not connected correctly. Shut down the system. Unplug the power cord from the system, open the case & re-check the data ribbon for correct orientation, solid insertion & solid insertion of power cable to drive. Connect the power cord to the system & boot to the bios again. Once the drive is listed go to the title Boot, section 2.6, page 2-27 & follow the instruction through to page 2-28.
Open your CD-ROM drive & load your windows CD, close the CD drawl.
Save bios changes & exit. The system will auto restart.
The system should start loading windows if you set the boot device correctly as shown in the manual.
If you find this too difficult to follow, suggest you ask a friend with more PC knowledge for assistance.
Mike
Jul 14, 2008 | ASUS K8V-MX Motherboard
Reboot
Hi satiewe, no not you're CD. You'll need to enter the notebook's bios. How to get into the bios? Right after you press the power on button, start pressing the delete key every two seconds. The bios main menu should load. If pressing the delete key fail to load the bios menu, try again & press the F2 key every two seconds. The main menu will look like this:
1583ec1.jpg Look at the bottom of the menu & there are instructions on how to move about while in the bios. Go to the title, Advanced.
Listed to the right of; [PATA Primary Master : xxxxx] Where xxxxx is the model number of the hard drive, (Ex: ST80325B). Write this number/letter down. Than go to Boot .
Under boot is, Boot Device Priority. The normal order should be;
1st boot device, [floppy]
2nd boot device, [CD-ROM] - model name.
3rd boot device, [Hard disk drive]? The name of the drive was listed at the main menu as, Pata Primary Master (What you wrote down is what must show here). Than save the bios change & exit. The system will restart. If you placed the correct drive in the correct order you're system will start up.
Good Luck!
Mike
Jun 26, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ASUS K8V-MX Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
