Question about Brother MFC-5440CN All-In-One InkJet Printer
I can't the scanner to scan... Please help!
The machine is out of ink but I should still be able to scan a document, right?
  • 685 Answers
Yes you should.
Posted on Feb 28, 2009
How do I scan a document into my computer
Place page on scanner, scan document and save as a PDF. You can now copy and past text from the pdf file. Look here, much better tutorial here: http://www.youtube.com/watch?v=NKHb0iEkSHE&feature=related
Sep 06, 2012 | Brother IntelliFax 1960C Color Ink Fax...
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Can i use the machine hp c5180 to scan document even if no ink?
Ria,
Please understand that the scanner and the printer have no connection. So, even if the printer is dead you can still scan. Yes, you will have problems when you want to print the scanned copy.
Feb 10, 2011 | HP Photosmart C5180 All-In-One InkJet...
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Canon DR-3080 CII scans only half or right side of document
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Oct 02, 2009 | Canon Office Equipment & Supplies
How do I scan a document please?!
you can a document using a scanner.
1. you have to find a SCANNER machine that is responsible in scanning the files you want to scan.
2. Then after you find a scanner, next thing to do is to place the document file in the scanner and make sure that your scanner is properly connected and turn on.
3. Click and run the software that is bundled with the scanner to scan the document and then you have to set the path where your scanned file is to be place.
4. Then after the scanning process finished then click the save button to save the scanned files.
Thanks
Sep 15, 2009 | Office Equipment & Supplies
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Scanner Problem
May need to open the top drag the scanner all the way away from its home position, and then turn on, let the scanner find its way home. May help
Jan 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
