Question about HP Deskjet 3915 InkJet Printer
My hp 3920 inkjet printer has no power, what should i do? The power supply is ok but when i press the power button nothing happens, no pilot light.
    Sergeant:
  • 199 Answers
Check adapter
Posted on Feb 28, 2009
Driver printer hp deskjet 3920
Click in the link below and click to select your operating system from the drop down menu then press "enter" . download and install. Thats it simple.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445442&cc=ie&dlc=en&lc=en&jumpid=reg_r1002_ieen_c-001_title_r0002
Dec 11, 2012 | HP DeskJet 3930 InkJet Printer
All 3 lights are flashing. I have tried everything the manual asked me to do
You may need to restart the printer.
1. Press the power button to turn off the printer.
2. Press the power button to turn on the printer.
Proceed to step 3 if the lights are still flashing.
3. Press the power button to turn off the printer.
4. Disconnect the printer from the power supply.
5. Reconnect the printer to the power supply.
6. Press the power button to turn the printer
Aug 14, 2010 | HP DeskJet 940c InkJet Printer
The power cables are working The printer clearly
i think you should check the cable that connects the printer to the computer. I suggest you change the cable and see if it works.
Aug 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
How to change a fuse in the hp 2800 printer, power up problems
There are 2 fuses inside the power supply unit.
The hard part is getting to the power supply! The power supply is located at the left side of the printer and in the front (the opposite side of the cartridges).
You have to remove the side and top covers.
There are some hidden screws. One is under the button faceplate that you will also have to remove. The entire procedure is tricky especially without a service manual. Unfortunately I couldn’t locate a manual.
Caution always disconnect the power lines and allow some time for capacitors discharge before you attempt any repairs.
I hope you have some luck with yours !!
Nov 13, 2009 | HP Business InkJet 2800 Printer
Hp f370 printer doesn't turn on
my hp f370 does not turn on anymore. checked the power supply adapter using a multimeter, the voltage are correct as per the label. when i press the ON button, nothing happens, not even a light will lit. what seems to be the problem?
thanks in advance.
Nov 10, 2009 | HP DeskJet F380 All-In-One Printer
Same problem, hp c6150 turns on and shuts down in infinite loop.
In visiting with HP Support Personnel, this issue is most likely caused by a faulty power source. I have the same issue with our C6150 and they recommended that I look at replacing power cable. I am currently trying to find a new power cable.
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Install HP Deskjet 3920 printer
Here is download page from HP
HP Deskjet 3920 Printer - Download drivers
Chose language and OS version. After downloading the file, double click on the downloaded file to start printer setup wizard.
Keep printer unplugged when you start installing files.
Sep 03, 2008 | HP DeskJet 3930 InkJet Printer
HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Deskjet 3915 InkJet Printer Logo
218 people viewed this question
Ben Johnson
