Question about Samsung DVD-VR320 DVD Recorder/VCR
Bought new discs will not initialise dvd -rw error message could not format due to error detection
  • hael_j_coats Mar 02, 2009
  • 29 Answers
I had a similar problem with CDs. The cure in my case was a new drive. It is possible that the lens on the laser is dirty in which case it should be cleaned. Your local shop should stock cleaning kits,
Posted on Feb 28, 2009
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw) that formatting dvd-rw issue. i found that dynex dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
Problem formatting mini dvd+rw disc
The full user manual is available at:
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
Pioneer dvr3100
hi.. the problem is not with ur DVD-RW disc... Its in ur device.Might be the device is unable to read the disc.. so better try to clean up the lense of ur device with the help of lense cleaner... it will remove of the dust so that it will be able to read the disc...
thank u
Feb 01, 2009 | Pioneer DVR 105 DVD-RW Burner
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
Camcorder won't format my DVD-RW disc
try a different brand of dvd recordable disks? maybe? that would be my suggestion before anything else...hope it helps.
Rabeka Jo
May 15, 2008 | Video Cameras
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Changing a -vr format
You're right - only DVDs initialised in VR mode can be edited on the camcorder. Those initialised in VIDEO mode cannot be edited on the camcorder, but can be played on most DVD players and can be edited on a PC.
The good news is, if you are using a DVD-RW disc you can change the mode by reinitialising it to be in VIDEO mode, but you will lose all the previous content during initialisation. DVD-R discs cannot be initialised.
See this Fixya solution for details on how to initialise a disc.
To Junie1939 - No, it's not possible to change a DVD from 'plus' format to 'minus' format, sorry - you have to go buy 'minus' format DVDs, or change the DVD reader on your PC. Remember the Canon DC210 only takes 'minus' format DVDs.
Good Luck.
Apr 27, 2008 | Canon DC210 DVD Camcorder
Not recognizing mini dvdrw
DVD-R discs can be used with no preparation, but a DVD-RW must be initialised before it can be used for the first time.
You may also have to initialise a DVD-RW if you get the message "UNABLE TO RECOGNIZE THE RECORDING MODE OF THE DISC" .
Also, make sure you always use DVD "minus" format discs - the DC210 will not work with any DVD "plus" format discs.
When you initialise the disc you will be asked to chose between Video mode and VR mode. Most DVD players will play a Video mode disc, but a VR mode disc can be edited with the camcorder. My preference is Video mode - I can then play on a DVD player and edit on a PC.
Apr 18, 2008 | Canon DC210 DVD Camcorder
Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
Apr 08, 2008 | Toshiba D-R5 DVD Recorder
Initializing disc
Yes - you're trying to initialise a +R DL.
Two problems
1. The DC210 only takes - format DVDs
2. You only need to initialise DVD-RW discs (see page 57 of the manual)
By initialising the DVD+R you have written to it once. having done that, you cannot write anything else to that disc. I find it easier to use DVD-RWs so that I can re-use them.
Good Luck.
Dec 01, 2007 | Canon DC210 DVD Camcorder
Samsung DVD-VR320 DVD Recorder/VCR Logo
265 people viewed this question
Jerry Greenberg
Jerry Greenberg
