I have a Melles Griot-dualbeam.-laser from Ebay. It is not anymore working. We prooft the lectronic, that seems to be Ok. Shortly it leghted op som time ago both beams had satelites. The mans had about 12 mWatts. No it is not working! What can I do with this? I am not a laser-specialist! I must look for help! Best regards Horst Gutekunst Mail:
3 Suggested Answers
  • 787 Answers
SOURCE: printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Posted on Nov 12, 2009
  • 1218 Answers
SOURCE: the message says "the waste
Check the following steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
Posted on Dec 16, 2010
My facebook won't work at all please help me
I don't think it is available from the manufacturer anymore, however if you enter Xitel Inport in eBay you will get a few hits, e.g.
This is Xitel Inport in a box and is selling for $29.95 (I paid $124 years ago and have never regretted it).
Jul 31, 2014 | Computers & Internet
Driver verloren
Mathieu, Let op dat je geen enkele schrijf actie naar de drive uitvoert.
Als jouw drive niet meer herkend wordt, moet je voor het operating systeem even de drivers installeren die te maken hebben met externe, USB drives.
Maar om zeker te gaan dat het aan de computer ligt, kun je modekijk bij een bekende de drive een keer aansluiten. Als blijkt dat de schijf wel herkend wordt, maar je kunt geen bestanden meer lezen, moet je een herstel programma gebruiken, zoiets als van Ontrack of soms kun je van firma\'s die geheugen kaartjes verkoken recover programma\'s ophalen.
Als blijkt dat je op een andere computer gewoon de schijf kunt benaderen, kun je met het (her)installeren van de drivers op jouw eigen PC verder gaan. Houd er rekening mee dat ook externe drives geen eeuwig leven hebben, Maak tijdig op een andere schijf ook een backup.
Een backup is geen backup. Zorg ervoor dat je tenminste naast de originele nog twee backups heb, liefst op twee verschillende media.
b.v. op externe drive en op DVD (blue ray) en of in de cloud.
Jun 01, 2014 | Seagate U6 (ST380020A) 80 GB Hard Drive
Need to change all three v-belt on a 1998 honda cr-v. just need to know what are the leght of each belts
I think that is hard to say .why do want to know the length, the parts store will give u the Right belt once your information is right , the u can find out which belt is for what. Ok
Oct 31, 2013 | Cars & Trucks
I have a 98 vw passat glx. the button which opens the fuel pump door does not seem to work. i have to press it about 20 times before the door opens. any solutions???
chances are the spring that opens the flap is weak,just replace the spring.if it gets stuck shut pull away the carpet/trim from inside the trunk to get to the flap wire.
Feb 01, 2011 | 1998 Volkswagen Passat
Its not the game. Unless its just in your copy as I've played it and others after that. Try taking your 360 disc drive apart and cleaning laser. If cleaning the laser doesnt work you might need a new laser which is under $10 on ebay. Hope this helps.
Nov 29, 2010 | Microsoft Xbox 360 Console
My ps3 does not read disc anymore games dvd blu ray
Ok it sounds like your blu ray laser has become faulty. Unfortunately this is a very common problem for the PS3 and there is not much that can be done about it. New lasers can be bought but they are difficult to fix. You could buy a new drive from somewhere like ebay at a cost of around £60. They are much easier to fit than the lasers themselves but you must make sure you keep the circuit board on your blu ray drive and swap it to the replacement drive as this is paired to the motherboard and will not work if it is not with the original motherboard.
Hope this helps and thank you for using FixYa
May 04, 2010 | Sony Playstation 3 (PS3) Console
Hello my sons ps3 has stopped loading games,
I have seen lasers burn out shortly after 1 year. They are available online for purchase. It would be the laser for sure if the system starts up fine, disks go into and out of the console and if there is an icon in top right of screen like it is trying to read. I have fixed a few but laser replacement usually cost $150. Good Luck
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Just bought a garmin 660fm on ebay it seems to work ok for around 20-30 minutes and then switches off, when i turn the unit back on it shows only one bar on the battery indicator and swithes off shortly...
It is the battery and since it is not under warranty you may as well open it up and replace the battery yourself. 1500 mAh, Lithium Polymer and it will unplug from inside the unit. $8.88 at the following url:
Jul 08, 2009 | Garmin Nuvi 660 GPS Receiver
My PS3 doesn't work anymore, the problem is that it does't spin the disk anymore. I though at firs it was becuase of a dirty lens, but then found the problem, what next?
your ps3 laser housing is gone....becuase its blu ray,these things dont seem to last long.look at ebay for laser housing for ps3 and you will find them..eassily fixable if you can buy the part..
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
137 people viewed this question
