Question about Intel D945GCCR Motherboard
USB Keyboard not working
My USB keyboard suddenly stops working. When it does, I can see the block num light sign twinkling, like if it was losing power. I also noticed that the LAN light indicator on my cablemodem also starts twinkling, even if no application is using the internet.
I tried updating the motherboard BIOS but the problem continues. I used a PS2 adapter and the same thing happens. I'm desperated.
  • Anonymous Apr 05, 2009
    i have 945gccr motherboard but usb keyboard not working when i put ps2 keyboard for checking purpose then it's working same usb keyboard working another motheboard via usb
  • 29 Answers
The lan light will obviously keep blinking bcoz of the data packets keep on transferring.......thats normal.....thats not a problem.
for ur key board switch off the num lock
Posted on Feb 28, 2009
Why did my num pad stopped working all of a sudden?
remove keyboard strip cable clean and replug
Apr 27, 2014 | Samsung Rv511
Comfort curve keyboard 2000
Have you tried my solution for keys not working here?:
http://www.fixya.com/support/t3015431-microsoft_comfort_curve_2000_v_1_key
Mine is toward the bottom, with the video
Good Luck
Jan 07, 2013 | Microsoft Comfort Curve 2000 Keyboard
Mini numeric keypad num lock problem with embedded keyboard
Plug in an external keyboard. Hit num lock. Bam!!! Problem solved
Apr 27, 2012 | HP 303178-001 Compaq TC1000 TC1100 Tablet...
Dell inspiron 1501 laptop keyboard is typing odd numbers and symbols instead of some of the lettters. Examples, the letter "l" comes out "3" . Other letters come out as a back slash, etc. A plug in USB...
Is the Num Lock light lit? This light is the one all the way to the left of several on the computer to the left of the power button (it looks like a padlock with a 9 in the center). The integrated number pad is probably active. Press to toggle this feature off. The Num Lk key is to the right of the various function keys but to the left of the keys labeled Insert and Delete.
I hope this helps.
Oct 16, 2010 | Dell 0Y3740 Keyboard
Dell dimension c521 keyboard failure.
Disconnect & reconnect the keyboard.
Check whether the num, caps & scroll lock light respond to keys. If don't contact service centre..
Apr 16, 2010 | Dell Dimension C521 PC Desktop
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
My keyboard wont work
if its a ps2 kb you prob just killed it by plugging it into a computer with power on. if usb than its ok to do that. if its not lighting up than its dead. get another kb
Sep 03, 2009 | Computers & Internet
Have plugged a MS USB wireless keyboard and mouse into USB port on baby - to use big screen and keyboard. It works well, but when I unplug USB keyboard, the baby's own keyboard won't work properly ie when...
Hello, your numlock keys are ON, find your Num Lock button and press it off.
It can be a 2 button combination like FN(function button) + Num Lock button. Then it should work.
other way is to press numlock on your external keyboard and then disconnect the board. see if it works.
Jun 26, 2009 | Advent 4211c Notebook
Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Nov 11, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Intel D945GCCR Motherboard Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
