Question about Brother XL-5130 Mechanical Sewing Machine
TENSION SETTINGS NEED THE TENSION SETTINGS FOR THE REGULAR SEWING DO NOT HAVE MANUAL XL-5130 BROTHERS MACHINE
  • Anonymous Mar 17, 2014
    where to set tension on my sewing machine
  • Anonymous Mar 29, 2014
    how do i set the tension?
  • 137 Answers
Try this URL.
www.managemyhome.com
Posted on Mar 02, 2009
Tension adjustments- bobbin metal or plastic-needle size- for sewing on jean cloth
Most machines can sew on jeans fabric, but you may need to go slowly or even hand-turn the needle when crossing thick seams to keep from bending or breaking your needle.
Bobbin: It won't matter if you use plastic or metal bobbins.
Needle: You should use a heavier needle - you can purchase 'jeans' needles, or use the heaviest sharp or universal needle you have.
Tension: For tension adjustment, you can follow the guidelines in your sewing machine manual but you'll also need to adjust the tension based on sewing on scraps of the fabric. If you are sewing light-weight denim, the settings are pretty much the default/normal settings. As you increase the weight/thickness of the fabric and seams to cross, you'll need to loosen your pressure foot tension. If you use decorative 'jeans' thread or topstitching thread, you'll need to loosen your needle tension.
*Always test on scrap fabric to make sure the stitches are forming properly. It is best to make small adjustments to your tension settings, then test, then adjust and test, until it is right. If you sew that weight of fabric often, make note of your tension settings inside your machine manual to save you some time the next time you sew.
I hope this helps.
Apr 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
The little thing that the needle goes into broke. How can i get a new one and what is it called? I have a Brothers machine XL 5130
it's called a needle clamp-check sewingpartsonline.com
on the left hand side click on brother parts
go down till you find your model number there is a brother xl 5130
it's close to the bottom of the page
please rate this with the thumbs in upper right hand corner
Aug 09, 2010 | Brother XL-5130 Mechanical Sewing Machine
Tension on reverse side of fabric is too loose-
Set the tension back to the recommended setting (in manual). This is usually around 4.
Always thread the machine with the presser foot up as this allows the thread to properly "seat" into the tension control.
Mar 23, 2010 | Brother XL-5130 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
The thread is gathering under the feed plate and not sewing correctly
The bobbin tension the this particular machine is not adjustable. You may need to take it in to be serviced and re tensioned. Hope this helps. Good luck.
The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Apr 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
CAN'T GET MACHINE TO SEW WITHOUT BREAKING THREAD
All you can really do it change the needle, make sure it is in properly (flat side to the rear) and make absolutely sure you have threaded it properly (presser foot raised when threading so the thread gets into the upper tension discs etc...) You can also check for lint in the upper tension discs, they should be clean. If none of this works then it may need to go to the shop.
Best of luck and happy sewing!
Feb 05, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
275 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
