Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a kitchen Aid Model KTRS22K water is leaking from the back of the automatis ice maker and freezing in the ice tray and on the back wall of the frezer. How do I fix it? Thanks
HVACRH20
  • 237 Answers
SOURCE: My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Posted on Jan 31, 2007
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
cresguy
  • 75 Answers
SOURCE: Not making ice
The oil from the compressor has pumped up to the top part because of it only the ice maker s not workind change the lead valve of the compressor which can rectify your problem
Posted on Jul 25, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
Tfx25ppbb. Water leaks into bottom of freezer when refilling ice tray in automatic ice maker. Ice still gets made but water leaks to the bottom of freezer. When enough freezes, it leaks out the door
It's probably not the ice-maker. It has a plugged drain. This is located in the back wall of the freezer near the bottom. remove the evaporator cover...(the back wall of the freezer). Below the coils is a trough with a hole in it where the defrost water drains. This is probably frozen over.
Pour some hot water in to trough until you see drain hole. Keep pouring until water runs thru drain. May have to shut down ref to get it to defrost.
Oct 20, 2014 | Refrigerators
Kitchen aid ktrs22k
You must have a defective defrost timer.
Jul 22, 2017 | KitchenAid Refrigerators
I have a kitchen aid refrigerator KSRG22FTSS01 that the icemaker continues to freeze up in the delivery tube, any suggestions why
This is the fill Tube to the Ice maker tray. It is freezing because the water valve is leaking a little even when it should be closed. This leak is now freezing your fill tube. If you defrost the tube it will work untill it freezes again. The only solution is to replace the water valve. The valve part number for your machine is 4389178
Jan 14, 2010 | Refrigerators
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
NO WATER IN ICE MAKER
From what you've described, it sounds like you have a defective inlet water-valve.
I would remove your outside rear bottom panel; disconnect the 2 prong wires connected to your ice-maker water valve (blue with black solenoids) and check for continuity using an ohm-meter setting. If defective, replace. Whats' your model #?
Jan 26, 2009 | KitchenAid Refrigerators
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
192 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
