Question about GE GTS18F 18.2 Cu. Ft. Top-Freezer Refrigerator with Clear Vegetable/Fruit Crispers & Gallon Door St...
I can't seem to get my refrigerator door to hang properly -
I can't get my refrigerator door to hang properly - there is about a 1/4 inch gap in the seal on the top right-hand corner. I have tried to adjust the wheels at the bottom to correct the imbalance but nothing seems to work. The refrigerator door closes if left open - so it is at level.
I can only put very light items on the shelves of the refrigerator door otherwise the gap increases. I have to manually lift and readjust the door height to minimize the door gap. Is there a simple way of correcting this problem? What am I missing?
3 Suggested Answers
  • 4 Answers
SOURCE: Refrigerator door is not shutting right
You need to replaced the door cam assembly on the bottom of the refrigerator side. It is probably cracked and hanging up.
Posted on Jan 09, 2009
  • 262 Answers
SOURCE: GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Posted on Jan 11, 2010
Testimonial: "Very detailed & quick support. Thank You"
The refrigerator door on my Sub Zero 695 is sagging. How do I determine if it is a problem with the bottom hinge or the closer cam. My cam looks worn, however the gap at the top pin is almost double t
The bottom cam should be in 2 parts, one on door and one one lower hinge. Sounds like your missing one of them. I would replace both of them at the same time to fix the problem. Good Luck
Sep 13, 2014 | Sub-Zero 695/S Side by Side Refrigerator
Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Sep 09, 2012 | Samsung Refrigerators
Hi, the freezer door will not stay closed. need to push the last 1/2 inch, sometimes it pops out again that 1/2 inch. nothing in freezer to stop it closing. Door need adjusting?? Greg
If the refrigerator is not properly leveled the doors will not close easily, the front side should be a little bit higher than the rear side. If that's how it is, then the issue is with the hinge lever that seems to have gone bad and should be replaced. Hope this helps...please post back for further assistance.
Apr 06, 2011 | LG LSC23924 Side by Side Refrigerator
Door needs to be adjusted as it seem to be hanging lower on open
slightly loosen the bolts on the hinges enough to scoot the door into the correct position and it will stay until you tighten the bolts on the hinges. It may take a couple of tries but that is the way to do it until the door seals and closes properly =)
Jun 24, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The refrigerator door seems to have dropped about 1/8 inch.
it is possible that the floor under the adjusting bolt has dropped,place a carpet protector cup under all the feet and then, using a level, make sure the unit sits square,the door may need some adjustment after this but you will see, that is a simple task.
Mar 31, 2010 | KitchenAid KSCS25FKSS Side by Side...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
Mar 31, 2007 | Hotpoint RLA80 Refrigerator
GE GTS18F 18.2 Cu. Ft. Top-Freezer Refrigerator with Clear Vegetable/Fruit Crispers & Gallon Door St... Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
