Question about 2wire 2700HG-B Router (2700HGB)
Network key retreival
I have a 2701HG-B Gateway wireless router, just bought a new computer and don't remember my network key to connect my new computer to the router for wireless access. I have the disc and installed it but am blocked from connecting to the secure connection.
    Problem Solver:
  • 17 Answers
Is it possible that you never changed the default wireless key? If you didn't, the number in '[ ]' brackets printed on the bottom label is the wireless key.
If you've changed that from the default when setting up your wireless network, you'll most likely have to reset your router.
Of course, if you do a reset on your router, you will also have to re-enter your DSL account / password in the router
Posted on Feb 28, 2009
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
Hi i want to chang my net password how to chang?
Hello
I got the information from the user manual on page 31:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf
Open a Web browser and access the 2Wire gateway user interface by entering
http://gateway.2Wire.net.
Click the Home Network tab.
Click the Wireless Settings link to open the Configure the Wireless Network page.
On the Wireless Security section select custom key ,enter new key and then click on Save at the bottom of the page.
By the way the default /current password is underneath the router.
hope this helps
Feb 17, 2012 | 2wire (2701HG-B) Wireless Router
My computer is connecting via The Crazies...whatever that is! I don't have or remember my security code for ATT 2Wire connection. Where did The Crazies come from and do I want to get rid of it?
It sounds like "The Crazies" is a wireless network near you that someone had used to connect to the internet using your computer. To connect to your own network, look under the router/modem itself near the barcode. There should be a few sets of numbers there. You'll want to enter the code in that is in brackets [ ] (should be under the serial number) into your computer when connecting to your network. That should do it, but let me know if you have any other questions!
Sep 17, 2011 | 2wire (2701HG-B) Wireless Router
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
I have a 2701HG-B gateway furnished by AT&T DSL I want to change to wireless\r\nWill my gateway work with wireless? I will have to install wireless cards in my computers what do you recommend? My...
You need a wireless router for you to use Wireless connection
I recommend DLINK, Belkin or Linksys router any of those will work.
you can still use wired connection because router has 4 ports for wired connection but if you prefer to use wireless then you need to buy USB wireless network adapter.
Sep 06, 2010 | 2wire (2701HG-B) Wireless Router
We need to unlock wireless network to operate an IPOD Touch. Do you have original or new pasword that will let us use the IPOD? Router is a 2wire model 2701HG-B.
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
May 01, 2010 | Computers & Internet
Where do i find the essid and key on the 2701HG-B trying to get a HP Photosmart printer to attach
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 20, 2009 | 2wire (2701HG-B) Wireless Router
Im a new compaq presario cq60 owner- im trying to setup wireless network at home-att.is my only option in my area- have a 2wire 2701hg-b wireless router and cant get it to work internet,wireless only with...
You will need to check the wireless settings of the router.
You said that it works only with the ethernet connection but not with the wireless connection.
Check the IP address of the computer when it is connected with the cable to the router. note down the default gateway number.
Open the set up interface of your router with the Default gateway number.
once you are able to open the set up interface of your router, you will be able to change the wireless settings of the router.
after that you will need to conncet to the wireless network on your laptop.
Click Here for more Information
Oct 06, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
98 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
