Question about Krups Small Appliances Espresso Machine
No coffee WE have XS6000, steam comes out hot water comes out. You can grind the coffe, but no coffee comes down from the machine. It goes directly to the drip tray without touching the ground coffehelp please
I had a similar problem with my XP 7240 with the coffee not coming out, but dripping through the machine and out the back. I found that overtime, there was a buildup of coffee in the "pod" area or percolation chamber and this was not properly removed. As a result, with additional cups being made, there was so much coffee compacted that it couldn't drip through.
I managed to clean it out by breaking up the compacted grains and it all worked fine. I also find that after each cup made, there is always some coffee grains left on the coffee cleaning tray above the grounds collector. I figured that this was the culprit as these grains would drop into the percolation chamber - adding this to the normal amount of coffee grains. It was never effectively cleaned out.
Now, I remove that tray after each cup, empty the grains and it seems OK. It's a pain, but I haven't had the problem for 2 months now.
Every now and then, I also get the vacuum cleaner and try to **** anything that might be oin there out.
Posted on Apr 17, 2009
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
I have a Saeo Incanto Tondo S Class coffee maker. It grinds coffe bean but coffe is not coming out. There is no water in dregs but only grined coffe powder. I can get steam and hot water and I do not find...
Hello Saaddition,
I understand that your coffee maker is not producing coffee. However, it is operating normal in all other respects. This is usually a common problem when the machine needs to be descaled. You may also need to clean the brew unit. Here is the link to the manual for you Saeco Incanto Rondo C class coffee machine it give you all of the directions to clean and descale.
One other question did you remove the dregs drawer with the machine off. If you did you will need to do cleaning to reset the machine as removing the dregs drawer with the machine off will not allow it to brew coffee.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the...
to have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Aug 22, 2010 | Ariete Cafe Retro Espresso Machine
My Saeco Incanto deluxe started dripping hot water from the steam spout outlet when coffee is brewing. It produces steam and hot water without any problems. It doesn't leak when it's in a normal state...
Either the grind is too fine and there is so much pressure that the pins in the steam valve are not working properly. First try to adjust grind a little coarser, it that does not work, then the pins in the steam valve need to be replaced.
Nov 20, 2009 | Saeco INCANTO DELUXE Espresso Machine
Gaggia baby 18 momths old water coming through steam bit but no water coming through coffe bit any suggestions libby
HI
If you have a pre-grind button on your machine, push it but don't put any coffee in the brew unit. Push any of the coffee buttons, and see if water will come out then. If it does not, then you have a plugged brew unit and the brew head needs cleaning. I have directions for cleaning.
Jul 13, 2009 | Gaggia Syncrony Compact Coffee...
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Krups Small Appliances Espresso Machine Logo
274 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
