Question about Sony Ericsson K510i Cellular Phone
SIR, AFTER FORMATTING THE PHONE THE RINGER VOLUME AND THE SOUND OF THE PHONE IS GONE LOWER. WHAT SHOULD I DO KNOW?
  • dasmintu81 Mar 02, 2009
    I didn't received any solution.
Please help me
imei :354350009291239
to vbag i don't know ????
behind_memory@yahoo.com
replay
Posted on Feb 28, 2009
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Sir, nokia model 2626 Ring tone sound not coming when incoming calls comes speaker option is function all ringtone sounds comes only vibration please solve it thank u
The ringer is gone bad. Go to service center and just ask them to change the ringer. It will cost less than 100 rupees.
Make sure the phone profile is not in silent or in vibration only...
Apr 19, 2011 | Nokia 2626 Mobile Phone
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
I have 4 KX-TG2740 units, each with 2 lines. One unit does not ring for line 1. It says "Ringer Off line 1". I can't figure out how to correct. Thank you.
Press CONF/FUNCTION key, scroll to Ringer Setting by using the up or down arrow of the center navigator key, then press the right arrow. Press the right arrow again at Ringer Volume. Press the down arrow to select Line 1. Press the up or down arrow to choose the ringer volume you want. Press the right soft key SAVE, a confirmation beep will sound.
The ringer volume can also be set while a call is ringing in on the line. Make a call to Line 1 number, use up or down arrow key while phone is ringing to adjust volume of Line 1 ringer.
The following link is for the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
Jan 31, 2011 | Panasonic KX-TG2740 Cordless Phone
2300 nokia ringer problem
sir my mobile nokia 2300 not ringing
Jul 14, 2009 | Nokia 2300 Cellular Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
AT&T Model#972 How to lower ringer volume?
Hey how are you ??? sorry I didnt see your post til today I'm supridse no other experts didnt reply to it :(
Any way here is your user manual
http://qwest.ettp.net/reference/ATT%20Model%20972%20Manual.pdf
and to solve your problem
When not on an a
call press a LINE
button, then press
VOLUME + to
increase,VOLUME
- to decrease
volume of the
ringer for that line.
View manual for details.,,,
And again I apoligise for the late reply Sir ,, I do hope all is well with you .. Regards
Jan 06, 2008 | AT&T 972 Two-Line Memory phone
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
Ringer volume
Here's a link to the user manual, it in pdf format so you'll need Acrobat reader. http://media.venda.com/btshop/ebiz/btshop/invt/cay222/freestyle2200.pdf page 18 shows you how to alter the ringer. Hope this helps
Feb 17, 2007 | British Telecom Freestyle 2200 Trio...
Sony Ericsson K510i Cellular Phone Logo
26 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
