Question about Kenmore 27032
Kenmore elite oasis 27082 - lid won't lock
Kenmore elite oasis top loader 27082 - lid won't lock. How do I reset? I had unplugged it and plugged it back in but lid won't lock?
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Washer will not power on and lid is locked
Unplug it and wait a minute or two, the lid will release. Take out the clothes, plug it back in, put it in spin and close the lid. If it goes back to work, good. If not, check Repairclinic.com for repair clues.
Dec 01, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: how do i soak whites in a kenmore elite oasis?...
There is not a program - you have to do it manually on this machine.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The washer lid is locked
I would try that solution where you unplug it for at least 3 min then hit power and stop stop a couple of times. Maybe it will reset something ???
Nov 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer has a dl code with nothing blocking the door. i have jiggled the grey wire on the control panel but that no longer helps.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Nov 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis also quit in the middle of the cycle - there seems to be no power to it. I can't get it to turn on and the door is locked. The clothes have been in there for a couple of days now and...
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$!$
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer has the code dl on it the lid wont lock and we cant fix it
Jun 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Oasis Elite Washer Lid does not lock
most likely lid switch/lock ..sensor is part of control bd haven't seen control bd indicate switch problem and it not being the switch
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Oasis top loader
How to reset the breaker, or changed plugs? I looked thru the whole use and care guide and didn't tell much about it!
Dec 22, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 27032 Logo
259 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
