Question about Schumacher 100 AMP. Battery Tester
Where can I obtain a wire diagram Schumacher BT-100
I have an older model Schumacher BT-100. The cables are in bad condition and were removed. Normally I would draw the circuit. Where can I obtain a wire diagram? Any info would be appreciated.
Really basic , one lead goes right to one side of resistance and the other goes to the other side but across the momentary switch (switch thingy @ bottom of instrument)
Posted on Nov 20, 2009
Battery check with voltage meter on ezgo golf carts
Not sure if you're asking a question or just making a statement, however a voltage check alone will not indicate overall battery condition or health.
You need to have a load test performed on the individual batteries in order to determine overall charging system health.
Try this resource: How to Check Golf Cart for Bad Batteries
Get yourself a load tester similar to this:
Amazon com Schumacher BT 100 100 amp Battery Load Tester Automotive
Feb 01, 2018 | Golf
Schumacher battery charger wiring diagram SE-275A
Request the wiring diagram directly from Schumacher.
Jan 17, 2018 | Schumacher Electrical Supplies
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring diagram se-4020 battery charger
try this web site Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
Issues with Schumacher Battery Charger SE-82-6 - Schumacher 3 Position Slide Switch (8 pins) - Does anyone know how the wires hook-up to to the pins on the back of the switch?
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Nov 27, 2010 | Schumacher & Fast Charge Starter Charger
Schumacher 100 AMP. Battery Tester Logo
460 people viewed this question
Top Schumacher Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Schumacher Measuring Tool and Sensor Expert? Answer questions, earn points and help others
