Question about Refrigerators
1 year old Frigidaire Side-by-Side wont cool
Our power went out for about 30 minutes. When it came back on, the refrigerator appeared to be working since the lights were on. However, later in the day we noticed a puddle in front of it and realized that although the lights were on it was not cooling. No reading on the temp controls and it is not making any sounds at all.
  • Refrigerators Master
  • 4,655 Answers
Find out if there was a power surge at your home or other homes near to yours. Also if your model has a circuit board a surge may have damaged the board. I am putting a link for another similar problem like yours for you to read and see if it compares to your problem. Let me know, Thanks, Sea Breeze
click link below
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
Posted on Feb 28, 2009
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer defrosted but refrigerator still works
Sounds like the compressor is not running properly. It will overheat and shut off, then restart after a few minutes when it cools off. Check the coils (on back or under) to make sure they are clean. You can do this with a vacuum, or a can of compressed air from the store.
Dec 31, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Frigidaire refridgerator #frt21prhw1, not cooling or freezing
You said, your frigidaire refrigerator are not cooling
Check the outlet that it is still has power. You can plug a small lamp in to test it.
If there is power, wait 5 minutes before plugging the fridge back in and then see if it reset the system.
And how old is the fridge?
If not then you have a bad thermostat or leaking freon, and the pressure is too low to cool anything.
Or,if the compressor went then you may find this article I just read interesting!!!!!!
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Please remember to enter a rating before you sign off!
Thank You, HUUUM
Oct 05, 2008 | Refrigerators
Refigerator wont cool or freeze
unplug it for 30 minutes and try again...same problem? if yes, then recharge freon
May 29, 2007 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
