Question about Sony VAIO V505BXP Notebook
Lcd has broken
I have toshiba satellite A 100, its lcd screen has broken. now can you tell that is it repairable??
or if i purchase a new one then what will be the price of it?
  • 129 Answers
It is definately no repairable. The price vary from one service centre to other. You can call up your local toshiba helpline to inquire on price.
Posted on Feb 28, 2009
The 17.1' display of my toshiba satellite P105 its broken, two white lines blocked de screen, and 1 half of de screen its blocked by blacki need the part number or de model of de display for replace my...
Just a quick note, before you go replace the entire screen, make sure it's not just a wiring problem. If so, it doesn't cost as much to replace the wires connecting the screen to the laptop. LCD's are much more expensive!
As for replacing the display, this website has information on the display, along with the ability to purchase it from their site. http://www.pelltechnology.com/Toshiba/Laptop/Toshiba-Portables-Satellite-P105-Series-S6024/Toshiba-Satellite-P105-S6024-LCD-Screen-Replacement-P350475.asp
Hope this works!
Apr 11, 2011 | Toshiba Satellite A105 Notebook
The LCD screen on my Toshiba L505D-S5965 is broken.
Here is a guide
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L500-L505/remove-lcd-screen-inverter-1.htm
Jul 08, 2010 | Toshiba Satellite L505-S5966 Notebook
Sirius stiletto 100 LCD screen partially broken
I do this repair for a broken LCD on the S50's. I am on Ebay and my user name is rarey57siriusXM. Look me up I also do LCD and scroll wheel repairs for the Stiletto 10 and 100's. Cost of this repair service is $24.95 and that includes free priority mail shipping back to you on all these different repairs. Thanks
http://myworld.ebay.com/rarey57siriusxm
Oct 30, 2009 | Sirius Hoods Stiletto SL100-PK1 Satellite...
Blank screen on Toshiba laptop
Are you fairly comfortable with taking apart your laptop? Purchasing a new LCD screen on ebay is both easy and affordable. The screen that you need is a 15.4" WXGA LCD Screen and can be found for less than $100. You could type in your laptop model number and you should be able to pull up a wide selection of LCDs to choose from. I would try to find a local computer shop that works on laptops and would be willing to replace the screen for you, or look up a guide on how to replace the LCD yourself.
Mar 17, 2009 | Toshiba Satellite A105-S361 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Broken screen on l10 toshiba satellite how can i tell if its just
Try anexternal monitor on it. If it works that then you just need new screen.
Nov 18, 2008 | Toshiba Satellite L10 Notebook
Toshiba
It could be quite expensive at a repair center maybe as high as 400-500 dollars, however if you have some expirence working on computers you can purchase a used screen from ebay or other sources for around 100 and put it in yourself. Follow this link for an overview of the procedure:
http://www.tomsguide.com/us/how-to-replace-a-broken-laptop-or-notebook-display,review-649.html
Good Luck
Jun 25, 2008 | Toshiba Satellite P105-S6104 Notebook
Nice blue screen
It can cost minimum $400.00 to $800.00 to repair and when you can purchase a laptop from Staples or Fry's, etc. for as little as $395.00 on sale it seems hardly worth it. The new computers are better and have many more features to choose from. Toss it and get a new one.
Jan 14, 2008 | Toshiba Satellite A35-S159 Notebook
Laptop LCD mounting bracket broken.
try ebay search for toshiba Satellite A105-S361 "for parts only". you may get one for less than $10.00.
Sep 16, 2007 | Toshiba A105-S4054 Notebook
Sony VAIO V505BXP Notebook Logo
52 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
