Question about Mitsubishi WD-62525 62" Rear Projection HDTV
GREEN BLINKING LIGHT OF DEATH..........
I have a wd52825 with a green blinking light that dont go off. I can not get the tv to turn on no more becouse of the green blinking light. The tv worked great and after haveing to unplug it to move it or a power outage it just keeps blinking now. At first I could unpluge and plug it in again and after doing that for a while it would work again but now the braker went in my apartment and am not able to get the tv to work again( just the blinking lght). I have been reading about the DM board being bad and the caps on it. I have the chassie all apart and I looked at all the caps and the only one I see that is puffed is one on the signal board. I am hoping someone could help me with this problem as I have spent alot of time reading on this problem and dont know what else to do. Please help and thanks Paul
  • Anonymous Mar 03, 2009
    i have the same problem the green light will not stop blinking
  • Mitsubishi Master
  • 16,974 Answers
You cannot tell what capacitors are bad just by looking at them. Some can fail without any outward signs. You need a special meter to test them.
Posted on Mar 17, 2017
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Hi, I have a Mitsubishi WD-52525, and have the
The DM is the second board in the chassis from the right side looking in the rear. The first board is the FMT. The second is the DM, third is the Signal and the one which is sideway across the front is the Power board. The Chassis metal shields have to be removed to access the boards.
Posted on Dec 02, 2009
  • 4 Answers
SOURCE: wd62825 blinking green light
I am also a member of the WD-62725 blinking green light club. I replaced all twelve of the caps I found with higher rated ones and the blinking light problem did not go away completely but I could get the TV synced in 5 or less cycles...for a while. I finally put the TV on an UPS and it did pretty good for about a year until, for some reason, my wife muting the TV would send it into a blue screen and then the dreaded blinking green light of death. I had collected a lot of forum notes and bought the manual (virtually useless) and remembered a post where a guy put a switch on the orange power wire going to the "board to the right of the DM board," as he described it. This was the last attempt for me so I tried it. The board's name is the FMT PWB and on his WD-62825 and my WD-62725 it is the right most board, looking from the rear. Coming off of the top of the board towards the back of the set is a 4 wire connector with one of the wires being orange. Cut that wire and splice 12" long extensions to each leg. Reassemble the TV with these two new wires hanging out the back. Solder an on off switch to these leads. I used and old PC power switch because it had large "On" and "Off" labels on it. I then screwed it to a hole in back with a 1" stand off. Its not pretty but functional. Now turn your new switch off and plug the set in. If it behaves like mine it will blink green for about a minute and then go off. Now turn the new switch to the on position and you are ready to turn on your set. I hope this helps. If it does give me some feedback at rocky_beech(at)yahoo.com. I only need mine to last two more years and my house will be paid for and then I will get the best I can afford. I hope they still have plasmas by then. Cheers
Posted on Feb 18, 2010
jdvillanueva
  • 2098 Answers
SOURCE: mitsubishi green blinking light of death
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Posted on Jan 11, 2012
Testimonial: "Thanks, I just ordered 10 of the caps online. I work as an electronics tech on an army base. I'll pull the board and fix it at lunch. Thanks for your response. It will save me some time. Jim"
SOURCE: blinking green timer light
i did the manual switch on the orange power wire on the fmt module,it still works so far... thanks
Posted on Feb 02, 2012
Mitsubishi TV How do I fix green blinhing light in mitsubishi DLP TV 52825
most likely its a bad power supply. the wd52825 is known for that issue. check youtube for repair videos.
Jan 28, 2015 | Mitsubishi Televison & Video
Mitsubishi wd 65735 green light is blinking when power is applied tv will not power up
Green light blinking is set trying to boot up, no boot and of course set will not turn on, boot should take seventy seconds or so from plug in, if it does not stop blinking that is called the blinking light of death, as so many had this problem, probable going to have to replace the chassis if it is original one and that is usually five hundred plus parts and labor, just Google the model number with problems to see what I mean.
Aug 27, 2012 | Mitsubishi WD-65735 Television
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
Mitsubishi green blinking light of death
Hi Jim,
Jdvillanueva
Jan 10, 2012 | Mitsubishi WD-57733 57" HDTV
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Blinking green light problem, where's the answers? green light continues to blink and it sounds like alot of people are having this problem. why did i buy mitsubshi? becouse i didnt know any better.
The blinking green light is caused by failed Capacitors on the DM . Replaceing the capacitors will usually correct the issue in most cases.
Dec 15, 2009 | Televison & Video
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
GOOD LUCK GUYS.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
