Question about Sansui HDLCD1908 19 in. LCD TV
Can't display 1440x900?
I can't seem to get the TV to display 1440x900 as a PC monitor. My video card (Radeon HD 4870) can output that resolution in 60, 75, and 90 hertz. When I try to run 1440x900 at 60Hz It flickers twice and goes black. It automatically resets to 1280x768. I am using a DVI-to-VGA dongle to connect to the TV. I have updated drivers and am using Vista x64.
  • Bob Citizen Mar 04, 2009
    I am having trouble using display modes that are not recomended the manufacturer in the owners manual.
  • 27 Answers
I have a different LCD TV and video card, but I have the same issue.
To work around it, I have to toggle to make it the primary output. It will not work if set to extended, or set to both screens.
Posted on Apr 02, 2009
Can you use the "Digital
Yes, you can use both, but not on the same tv at the same time.
To get the same image both on the monitor and the tv you must use a tv that can use the same resolution as the monitor , then, from the Catalyst Control Center, you enable Clone
Apr 10, 2011 | Gigabyte ATI RADEON 6950 HD 800MHz 2GB...
Monitor says Analog RGB 1024 x 768 / 85 Hz Out of Range
install an AGP card into an AGP slot. use 8X AGP card then you can see high resolution because internal display card does not support to high resolution
Apr 02, 2010 | Xerox XR619DW Monitor
I have a 2007 Mac Pro with a Radeon graphic card. It's red and plugs into the tower main frame. I recently purchased an LED cinema display and the mac sales rep said I needed to upgrade my graphics...
in this case it sounds like you will have to replace it, but why won't the GFX card you have cope? resolution or connectivity. The Radeon HD 2400 is quite a capable card.
Jan 07, 2010 | ATI RADEON HD 2400 PRO Graphic Card
Windows XP Not displaying fully on 1440x900 resolution.
If you have one of those older CRT monitors you should be able to resize the image. Some LCDs have screen shifting tools too. Try doing a full restart, too. (shutting your computer down, waiting 1 or 2 minutes, then starting it up again.)
Nov 09, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
An incompatible video signal has been received check the output device settings connecting a sharp aquos to my ati radeon HD2400
what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Oct 07, 2009 | ATI RADEON HD 2400 PRO Graphic Card
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Video screen on thin client
You will find your Graphics card driver here: http://www.nodevice.com/driver/Radeon_7000/get34927.html
Am not sure that you can achieve your desired resolution of 1440x900 though?
Apr 08, 2008 | ASUS RADEON 7000 32mb AGP video card...
Sansui HDLCD1908 19 in. LCD TV Logo
434 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
