Question about HP Pavilion a1730n (RK574AA) PC Desktop
Mouse and keyboard do not work.
I have a hp a1730n. When the screen loads, it loads until the user screen. Everything is plugged in correctly, but the mouse and keyboard do not work. When I move the mouse before the screen says microsoft corporation, it responds. But after that screen fades and the windows user screen loads, the two lights on the connector are on, but the mouse and keyboard themselves do not respond. What do I do?
  • Anonymous Mar 18, 2009
    Did anyone find a solution to this problem. I also have a computer where the mouse and keyboard respond, right up until windows fully loads. This computer does not have ps2 ports, so I can only use usb. It is a new computer, just finished installing software on it. Not likely a virus as the first piece installed was antivirus. I had just installed an N-Computing desktop virtualization card in it. Likely it is an irq conflict. Not sure how to fix this if I can't get into windows... not even in safe mode.
    I did remove the card, however, it still does not recognize the mouse and keyboard.
    Any suggestions?
  • Jim Scott May 11, 2010
    have you tried going to add new hardware ?? also try moving the keyboard and mouse to different ports
    President:
  • 1,223 Answers
U can buy usb version of both mouse and key board if u are trying PS2 type connector check out the pins are they bent or damaged try to straighten the pins with a pointed object see connector of both
pls rate me if i fixed ur problem
Posted on Mar 02, 2009
I have a Avocent KVM I can swicth in between computers but the mouse and keyboard will work on one but not the other. I have reseated everything restarted multiple times to no effect.
Boot the computers in order making sure the one you are about to switch on is selected on the switch. Start with 1, then 2 etc. Make sure the computer fully loads and then log into it before moving on.
Oct 18, 2017 | Avocent Computers & Internet
USB ports fail - no mouse or keyboard on start up on hp pavilion desktop p6000
some older computers don't load usb devices until after windows is booted and in such instances usually a traditional ps2 mouse and keyboard (green and purple plugs respectively) are the best option to enter the bios or boot from cd/dvd
Jan 19, 2016 | Computers & Internet
Am using Win XP When I turn the pc on with recovery disk inserted the Press Any Key to boot from cd" screen comes up but pressing any key does not get a response then it continues on to the sign in...
OK! Lets troubleshoot this together.
First thing we want to do is verify that your keyboard & mouse and plugged into the correct places and are powered up and able to work.
Turn your computer on and look at your keyboard and tell me if any lights are on to show that it has power and is operational.
Watch the keyboard lights until the computer gets to the login page and tell me if the lights come on and stay on? Or do the lights turn on for a moment and then turn off again?
If you do not see any lights, please clarify if there are NO LIGHTS on your style of keyboard or if there are lights but they are not lighting up.
If your keyboard has lights and they are not lighting up at all, then turn off the computer and unplug the mouse and keyboard and swap them around. Then turn the computer on again and tell me if the lights come on and the mouse and keyboard become operational.
Once we verify this we can continue to the next step of troubleshooting. Please report what you find and I will help you solve this.
Nov 08, 2010 | IBM NetVista PC Desktop
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
Wireless mouse and keyboard issues
If you have both sets of keyboard and mouse plugged in, turn off the computer and remove the old mouse and plug in the new mouse. Reboot and if necessary use the keyboard to login. Once windows is loaded let it detect the new mouse and then shut down again. Take out the old keyboard and reboot. You should now be able to use both new pieces without problems.
Jun 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell C521 Will boot to User login But cannot use mouse or keyboar
If it is a USB then it should work with any keyboard and mouse. When you say it shuts off after XP loading screen, does the machine power off? have you tried unplugging the mouse and keybaord and let Windows load?
Mar 10, 2009 | Dell Dimension C521 PC Desktop
How do you disable the HP info center pop up
I had a user with the same problem using a Microsoft wireless keyboard and mouse. This is a similar setup to most Logitech wireless desktop kits, there is one wireless receiver for both devices and it has a USB connector as well as a normally unused PS/2 (it comes with an adapter for the USB so you can use this on an old computer without USB). The user went on a trip and another "helpful" user that was in his office noticed the wireless receiver's PS/2 cable unplugged and decided to plug it in for him. I'm actually amazed that it worked as well as it did but Windows didn't recognize the keyboard correctly (103 key keyboard?). All I did to solve this problem was to unplug the PS/2 conector and load the correct software for the keyboard. I also put tape and a note on the unneeded connector to prevent this from happening again.
Mar 02, 2009 | Logitech Computers & Internet
No mouse,no keyboard, and no monitor?
try to connect it with other keyboard,mouse and monitor....if they will run, the keyboard,mouse and monitor may be defective or damaged..but if they did not run properly,,
maybe somethings wrong wit your unit...
try to connect it first and see whats the result...
please tell me what are the results...
you may post it here...
chaw
Jun 17, 2008 | Computers & Internet
back up everything important you have like pictures,songs,documents .
then go for a restore
you might have got restore discs along with the computer use them and take the system back to day one
you will loose everything you put on the system but you will have to back up data first.
Acer monitor frozen & curser will not move.
If your mouse will not move, it is a problem with the computer, Make sure you're plugging it into the correct port. If it's a ps2 mouse don't plug it into the keyboard port by mistake.
Does the keyboard work? If you press the windows key does the start menu come up?
If the keyboard works, try using a USB mouse. If the keyboard does not work, try plugging the keyboard in where the mouse is and the mouse in where the keyboard is.
Feb 09, 2008 | Computers & Internet
HP Pavilion a1730n (RK574AA) PC Desktop Logo
172 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
