Question about GE 106591 Coffee Maker
Machine Leaks I've had this machine for 3 weeks and it leaks horribly. During the brew process, water leaks out from around the portafilter, and from around the outside of the portafilter housing. It also seems that water has begun leaking from a spot just above the water tank as well. It's not the grind or tamp of the coffee as the leaking has occurred with no coffee in the filter. We've cleaned around the gasket, so that's not the problem either. What's the deal? Or is this just one of those things made specially for Wal-mart that's just not up to par with everything else (like so many other things I've found there). Help.
  • swittmier Feb 28, 2009
    Actually this leaking machine is the espresso maker model #169108 not the 106591 coffee maker.
  • swittmier Mar 02, 2009
    Sandmanmc:
    No s*!$ Sherlock. That's not what I was asking. I'm very well aware of warranty programs, but I'm one that likes to try to sort out a problem first if there's a way. Please don't waste my time again.
There's a little known thing called a "warranty", and if you take it back to the store, you can get another one FOR FREE!! or your money back - You get to choose...imagine that??
Posted on Feb 28, 2009
  • Anonymous Mar 02, 2009
    haha...sorry, I know I'm cutting into your valuable coffee machine repair time.....hahahaha. get some caulking and seal it up!
Excessive water comes out the drain when brewing a expresso
Hi
Your 3 way valve is dirty or bad. Have you ever done a back flush with a detergent?
About every 3 months it is a good idea to do a backflush your machine with a blind filter basket. When backflusing you should only use a good espresso machine cleaner designed for an espresso machine's brew system. DO NOT USE a decalcification cleaner. First, clean the screen and dispersion plate plus the brew head and reassemble, which will prepare you for backflusing. Then, insert the blind filter basket into the portafilter with a ½ teaspoon of cleaner in the basket. Next, place the portafilter into the brew head and tighten. When the machine is hot turn on the brew button for about 10 seconds and then turn off. Then, wait 30 seconds to a minute. Next, turn the brew button on again this time for only about 3 to 5 seconds and then turn off. Wait 30 seconds to a minute. Repeat these last two steps six to eight times. After you have completed the backflushing remove your portafilter and rinse the blind basket with fresh water. Next, you turn on the brew switch to rinse the plumbing. Then, reinsert the portafilter into brew head and turn on the brew button for about 10 seconds and then turn off. Next, turn on the brew button for approximately 3 to 5 seconds and then turn off. Repeat about 4 to 5 times. Always remember backflushing is hard on electric 3 way solenoid valves, so it is not recommended do this no more than four times a year for a machine used in home application. You will find more good is done to your machine be properly cleaning the brew head.
Apr 23, 2011 | Pasquini Livia 90 Espresso Machine
My portafilter is leaking during brewing. seems it can not get as tight as it previously was able too. I have the model with the 3 settings and even on Ristretto, the coffee comes out way too fast and the...
You need a new brew head gasket. They are not that hard to change. Four nuts hold the chrome head on. Once the chrome head is removed the gasket is pulled off then the brew head is cleaned and then you can put the new gasket on. Check ebay.
Feb 06, 2011 | FrancisFrancis! X1 Espresso Machine
Leak around filter
Any leaks aroung the portafilter is usually the brew head gasket. You just need to replace the gasket. The gaskets only last about 1 year so if yours is older that that, it needs to be replaced.
Dec 07, 2010 | Isomac Millenium Espresso Machine
I have a Silvia which is about 6 years old. Over the last few weeks, when I am brewing coffee, some water leaks around the portafilter. The portafilter is well seated and properly tamped. How do I approach...
Have you ever changed the brwe head gasket? It should be changed yearly at least. They get hard from the heat and won't seal. They should be soft to make a good seal. You can change it your self. I have left post on changing gaskets. Look for Silvia solutions.
Nov 14, 2010 | Rancilio Silvia Espresso Machine
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Water leaks around the pod holder on my X5.
try inserting the portafilter a little farther in group if it passes 90° then you will have to replace the group seal.
May 19, 2009 | FrancisFrancis! X5 Espresso Machine
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Problems with handle alignment
I had to use some olive oil around the outside of the filter cup holder to get it to move all the way to the right. After the first couple of times I was able to get it on straight without any oil...
Mar 15, 2008 | DeLonghi EC155 Espresso Machine
GE 106591 Coffee Maker Logo
235 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
