I need to manually ad way points to my 400t. how do I enter the latitude and longitude?
SOURCE: latitude longitude
Create and save a waypoint for any location then update that waypoint with the lat/long you were given (just click on the lat/long and key in the new coordinates).
SOURCE: my garmin 760 suddenly lost it's data and
Its possible that the data is corrupt.
One possible fix is to perform a hard reset on the unit.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the device has been hard reset, you will have to perform the set up procedure again upon start up.
Once the unit is has been reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to fix to GPS satellites.
Not a gurantee, but its worth a shot.
SOURCE: I have a Garmin etrex legend, and when I enter the
Go to Main Menu > Setup > Units > Position Format > change to hddd.ddddd format. This is the decimal format which is widely used by geocaching forums.
Page 44 of your User Manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
If this solves your problem, please come back and rate our solution. Thank you.
