Question about Reebok Exercise & Fitness
Treadmill may be slipping
Treadmill seems very jerky when you run or walk. doesn't seem to matter what speed. feels as if it gives a little when your feet hit the mat.
    Problem Solver:
  • 14 Answers
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Posted on Mar 02, 2009
I have a Horizon LS925T treadmill. It seems to jerk. I don't think the belt is slipping, more like the power roller is erratic. It rolls smooth then slows for a second which jerks the belt. Help.
Hi There, This sounds like the control board may be failing. Can you see the control board? Check the 3 larger capacitors for doming or bulging on the tops, which is a sign of high internal heating of the capacitors. This board, 032671 can have issues with these caps. Lubricate deck well, free spin the walking belt by hand to feel for jerky rollers and flat-spots in bearings, if all feels smooth, that controller is most likely at fault or a failing motor with partially shorted windings. Contact jatinah@rocketmail.com for more help if needed.
Mar 24, 2017 | Horizon Exercise & Fitness
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Healthrider 500sel
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
Oct 30, 2011 | Exercise & Fitness
I have a Healthstream Ge3400 Lightning treadmill and I need to know how to tighten the belt as I can't find the user manual for it, It has been ages since it has been used and when you walk on it even...
hi,
Here is the steps to adjust the treadmill belt,
(1). Turn off the treadmill and remove the plug from the wall outlet to make sure it doesn't turn on during the readjustment process.
(2).Tighten the roller bolts on the rear of the treadmill belt with an Allen wrench. Tighten both the right and left bolts with 1/4 turns.
(3).Avoid tightening the bolts more than 1/4 of a turn at a time. If the belt is tightened too much, it may cause damage to the belt, which would require a replacement.
(4).Plug the treadmill into the wall and press "Power."
(5). Select a program and begin walking. If the treadmill is still slipping, turn off the treadmill, unplug it and tighten the bolt a 1/4 turn again until it is properly adjusted.
watch the following video which will help you to do the same.All brand hve the same procedure for tighten the walking belt
Sep 04, 2011 | Exercise & Fitness
I have a Pro-form 595PI treadmill..bought it used and has been working great until now.It seems that when I get on it , it seems to be slipping and not a fluid motion to walk or run on...Whats up???
check tension on the w/belt to loose will make it slip other wize check your drive motor belt thats under the hood. if you see a bunch of black dust your belt is worn replace
Mar 17, 2011 | Proform 595 PI Treadmill Walking Belt
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
May 13, 2010 | Tunturi T60 Folding Treadmill
Belt stops/slips
Sometimes tightening the belt is not the problem> What I would be doing is to get on the machine a determine which of the belt is actually slipping. What happens if the drive belt is glazed slippage occur no matter what you do. With the running belt you may have to it limits of adjustment and the belt can be stretched that no matter how you adjust it it will slip!!
Mar 14, 2010 | Weslo Exercise & Fitness
Proform 840 belt feels bumpy when in motion. Treadmill is over 10 years old, but has not been used regularly over those years. I started to use again a few months ago for running and very occasionally...
I don't think it needs a part - I believe the walking belt just needs to be adjusted - if you don't know how to do this then give me a call and perhaps I can walk you through it - my name is Dewayne
Feb 03, 2010 | Exercise & Fitness
Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Jul 30, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
563 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
