Question about Vizio L32 32 in. LCD HDTV
Light blue line from top to bottem
Its happened to me twice ive found just lightly taping the screen on the line fixes this but is there a real solution?
  • 718 Answers
This problem sounds like it is the connection cable for the LCD controller (TCON) board. Someone knowledgeable about electronics can take the back off the set and carefully disconnect the LCD controller from the LCD panel and carefully reconnect it. Try the set before you replace the back to verify it works ok before replacing the back. You may have to try this several times. The flat ribbon cable seems to alway cause problems.
Posted on Mar 05, 2009
Blue error light
if the blue light is on it means that the blue cartrige is all most empty and you need to buy a new one to replace it, you can check the status of the toner if you click on the samsung symbol in your Taskbar on the bottem of your screen.
May 17, 2011 | Samsung CLP 300 Laser Printer
Dark blue ink splodge on my computer screen
Check the warranty - I recently got an acer lcd from a friend (purchased as package deal like a eMachine), he bought a new one, and found it was still under warranty.
Try "Auto Reset" on the monitor setup panel, on monitor - not on computer.
I forgot the proper name but one of the light emitting diodes might have gone bad which causes lines, streaks and blobs (same as on laptop screens).
Apr 04, 2010 | Computers & Internet
HITACHI 53SBX59B, projection lights don't line up.
You need to have the covergence adjusted.  Consult user manual for instructions on how or have a professional do it for you.
Jan 04, 2009 | Sprint Hitachi P300 Cellular Phone
My sidekick screen is broken....
it's like $50 to $60. purchase the screen and go to local store to fix
Jun 06, 2017 | Cell Phones
Picture shrinking top & bottem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Nov 16, 2008 | Zenith R40W46 40" Rear Projection...
Blue Horizontal Lines
if you dont have time to get it fixed, tap on the side where the tape goes in. I had to tap it a couple of times before everything started work fine again.
May 06, 2008 | Panasonic Palmcorder PV-GS15 Mini DV...
Big blue dot
This is going to hurt..
You probably have a polarizer failing on one of the LCD panels inside.
There are 3 of these in LCD projectors, red, green, and blue. They all get the light fed into them, that light is then combined and fed through the projection lens.
You will need to contact Sanyo to find a service centre to replace it.
Apr 17, 2008 | Sanyo PLC-SW30 Multimedia Projector
XBOX 360 ERROR E67
ive had mine for a year and a half mine did that twice . i found that my hardrive was loose so make sure its connected all the way and if it is just take it out then put it back in
Oct 07, 2007 | Microsoft Xbox 360 Console
Blue Lines
I have the same problem with my Panasonic and have not taken it in yet; however, understand that its a simple fix of running a cleaning tape through it.... Ill try this...
Nov 06, 2006 | Panasonic PV-GS150 Mini DV Digital...
Vizio L32 32 in. LCD HDTV Logo
128 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
