Question about HP OfficeJet Pro L7580 Color All-in-One Printer
"Door Open" error message
Printer: HP Officejet Pro L7580
Problem: Cannot print because of "Door Open" error message.
  • 129 Answers
Check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Posted on Feb 28, 2009
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
My HP officejet pro L7580 has stopped printing black. The cartridge has been replaced ( HP original) . Other colours are fine. Printheads are fine. Error message on display: Alignment failed - Refer to...
On this HP the print head is not part of the cartridge. How do you know the print head is fine? Did you just try to do a test page without an alignment?
I know that HP (they suck) will not help you because you are past warranty - Google your question since I am sure that you are not the only person to have experienced this issue.
I think you have a bad print head.
Sep 18, 2017 | HP Officejet Pro L7580 All-In-One InkJet...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7580 won't print
Try this. Go to WWW.hp.com and let the website find your printer and install the sotware automatically.
Jun 20, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
My HP L7580 is messaging that the back door is open. All functions are unable to perform. The door is shut, to the best of my knowledge
laser printer have many sensor at defferent unit like paper input cartridge fuser paper output and some cover, you may try to check a sensor at back cover somewhere around the cover edge that look like a small switch, it can be actived by the cover, the error occur if the small switch not active, press the sensor then power on see what happened, no error you may adjust the sensor position that can be active by the cover. still error need to check the sensor or repair it.
Dec 27, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
817 people viewed this question
Ben Johnson
