Question about HP 1020 Plain Paper Thermal transfer Fax
Whether paper jammed? - HP 1020 Plain Paper Thermal transfer Fax
  • HP Master
  • 13,433 Answers
Give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
My printer is constantly jamming papers. What maybe the cause and how can I prevent or solve this?
Its possible the paper is not good for the printer or the internals are dirty. Check your printer physically and run the cleaning option and try again.
To avoid a jam:
  1. Use only one kind of paper at a time in your input tray.
  2. Whether you have a single input tray in your printer's driver or many input trays, tell the printer what kind of paper you have in the tray: Most printer controls include a section or drop-down list where you can pick a paper by name, type, thickness, or other quality.
  3. If you aren't sure whether your printer takes a certain kind of paper, check its documentation.
  4. When you reload your input tray, pay attention to the tray's needs, such as how the paper should be loaded and whether the length or width guides need adjusting.
Mar 09, 2015 | Samsung SCX 4623F - multifunction fax /...
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
Printer paper jam
hi and welcome to fixya
jamming of the printer paper is due to the issue with the paper tray and this is the hardware problem your printers paper tray back should be greased ! you can whether do it your self or go to an expert
hope that's helpful
Dec 07, 2012 | Xerox Phaser 3117
IT IS JUST RED BLINKING AND DOES NOT PRINT
Red blinking could indicate out of paper or out of toner. Be sure to check which light is blinking; the one for lack of toner or paper.
Check whether the paper tray has any paper and if it has, is it properly closed? Check whether it has a paper jam also.
Check the toner cartridge and ascertain whether it has anything. Lastly open the top cover and close it again for the printer to re-initiate itself.
May 26, 2011 | Kyocera Mita FS 1010 Laser Printer
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
How can I find a paper when it jams in this printer I can't find it
open the front cover and remove the toner cartridge and check for any paper inside the printer. or open the back door and see whether any paper jam inside the fuser unit.
Sep 25, 2009 | HP LaserJet 1320n Printer
Paper Jam
well..first thing is to try another type of paper.
Aug 12, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Priter Jams
Sometimes this happens when the paper is too thin. Have you tried ordinary substance 20 paper? Also see if the guide for the paper is set correctly according to the size of the paper that you are using. this especially happens if the guide is not able to correctly set the paper straight before it is fed
Aug 06, 2008 | Canon PIXMA iP90 Mobile Printer
Papper jam.
Open door to see whether do you do have any paper jammed. Sometimes, printer does not have a paper jammed but error still appears out of no where. Just open the door and close it again.
Hope this helps!
Apr 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP 1020 Plain Paper Thermal transfer Fax Logo
130 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
