Question about Dell Dimension 4300 PC Desktop
Dell 4300 freezing up
The install disk freezes up on pci bus driver my error  is that solution the same fix for this error
  • John Miller Jr May 11, 2010
    Can you elaborate in more detail? What precisely are you trying to do?
  • 32 Answers
Your cd may be scratched or bad in some manner and cannot read the cd beyond that point..steve
Posted on Feb 28, 2009
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
System bios version 2.84 bus:06 device:01,function:00 ERROR RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:00 RESOURCE CONFLICT-PCI IN SLOT 03 bus:06 device:04,function:01 RESOURCE CONFLICT-PCI...
http://www.smartcomputing.com/Editorial/article.asp?article=articles/2004/w1509/06w01/06w01.asp&guid
This is an article on basic troubleshooting since that sort of bios error could be anything from video card to harddrive.
If i were a betting man i would say the HD is toast at some point, so before you update next time try and Check Disk to see if you pass...
You can also download some slaxware linux distro's and put them on a USB stick for other diagnosing tools.
Have you installed anything new? Did you add any hardware, etc? Are we talking OEM vista in which case some manufacturers have to take the original OS off the disk...
If i were you i would get a new HD and try out a fresh install...
Jun 22, 2009 | Acer Aspire 5100 Notebook
There is no sound drivers are installed and all text is shaded
Hi
This is the software issue. Need to install the appropriate software to reslove this issue.
1.Ethernet controler - Need to install the chipset driver and the Lan driver
2.Pci bus device - Chipset driver
3. sm bus controller - After installation of the Chipset driver - Right click on the sm bus controller and update the driver - select install from specific location - i will chose the location- Select the model and hardware type as thermal sensor
next - follow the instruction.
4. video controller - Need to install the VGA or Display driver
5. video controller (vga compatiable) - Need to install the VGA or Display driver
With regards
anand_anj2005@hotmail.com
Apr 12, 2009 | Computers & Internet
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Reinstall cd
If you have connected any PCI device just remove it while installing XP....
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
Freezing
ok, the dark006 user is right with the F11 on splash startup screen. you do not need any disks 4 it. if you have any more questions, please email me at meanness628@aim.com
Jun 23, 2008 | Acer Aspire 5100 Notebook
Error message, need help
1. Turn off laptop, unplug all devices and cables.
2. Flip laptop upside down on towel (avoids scratches)
3. Open the PCI panel (you need screwdriver to fit screws)
4. remove the PCI card inside (probably 3rd party WIFI card)
5. reattach AC/PSU cable and start laptop
6 If it starts properly now, you either had a bad PCI card, or it was improperly installed. You can try installing it again (turn everything off first). Sometimes this error is just from the card getting loose, or oxidation on contacts. Insert and remove it 2-3 times to see if it works then. Let me know.
Feb 12, 2008 | Acer Aspire 5100-5022 Notebook
Dell Dimension 4300 PC Desktop Logo
Alun Cox
