Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
ALPINE PDX 1.1000
my alpine amp was working great one day and out of nowhere while is was knocking one 12 inch JL W6V2, tha amp cut at high bass. now there are two lights on both sides of the control panel to control gain and such, the light on the right is RED, and the light on the left is blue, it will turn on but will not send power to the sub, any ideas? i din't think that one 12" W6V2 was too much for that amp? if anything the amp should've been too much for the sub.
any ideas fellas?
thanks!
  • carsperson Feb 28, 2009
    but would ohms really matter if the amp can take a 4ohm or 2 ohm load? and still send out 1000rms? tthe W6 is a DVC and i have it wired parallel. sounded great before and out of nowhere it just has this red light bro..no burning smell of nothing, i even opend the amp, all is well inside
  • Anonymous Mar 01, 2009
    o ok i'll have a look at that man thanks a lot, and i'll get back to you!
    Scholar:
  • 156 Answers
Well you would have to look into the ohms of the amp compared to the ohms of the speaker. If the ohms are different you would have to hook them up in a different way. check the RMS on the speaker as well as the amp, this can also be sufficed by wiring it different if ohms match up properly! Hope this helps you out and if this is not the case let me know.
Posted on Feb 28, 2009
  • Zachary Kloefkorn Feb 28, 2009
    this all depends on what the speaker is as well and which wiring diagram it entales to hook it up. If all that is fine your Amp went into what i call a freeze mode. You may want to adjust a few of your bass curve knobs on the side because your DB might be too much or you took your stereo up to high at one point and the amp needs to be back to normal to read.
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
May 26, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
488 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
