Question about Xerox Phaser 6360DN Printer
Xerox Phaser 6360 turns off immediately after it is turned on
Printer suddenly stopped working. After working well for 3 months (low usage), all of a sudden when powered up it, the display would come on for a few seconds and then the printer would shut off. After trying it several times over a couple weeks, it shuts down immediately after power up (no display at all, no sound).
Is this a common problem for this printer? Any ideas/suggestions?
Dave
  • David Furniss Feb 28, 2009
    Cannot reload drivers because printer will not turn on.
  • 54 Answers
No is this ur printer is laser or inkjet means because of low usage one the printer will be on but no usage so try uninstall the print drives install newly and then try sitll it has problem means problem is with the main board
Posted on Feb 28, 2009
How do I Reset the Maintenance Kit Life count on a Xerox Phaser 6360
Your just not meant to.
Fit genuine Xerox parts and have no further problems.
Good Luck.
Jul 17, 2014 | Xerox Phaser 6360DN Printer
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 laser failure code 07
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Apr 22, 2011 | Xerox Phaser 6360 Laser Printer
Are LD products safe to use?
Safe , most likely, recommended? I don't recommend using generic supplies in anything but ink ket printers. By that I mean the liquid inks. The toner is a phaser is pretty unique, and the OEM toner is by far the best way to go.
Jan 20, 2010 | Xerox Phaser™ 6360/DT Printer
Cannot install Xerox Phaser 6360 Laser Printer" on vista
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=6360&ripId=&Xtype=download
open the above link.it takes you to the download page
Nov 03, 2009 | Xerox Phaser 6360 Laser Printer
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Phaser 6360 laser failure code 07
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Feb 25, 2009 | Xerox Phaser 6360 Laser Printer
Market projection and price of of this product Xerox phaser 6360
50,000 pages a month and depending on features, $1400 to 3000.
Feb 02, 2008 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 6360DN Printer Logo
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
