Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
How to use a 80gig zune on the im600
Do I need an adapter cable.
AC adapter not charging system
The low battery light may be indicating that the battery needs to be replaced.
Nov 28, 2013 | Altec Lansing Inmotion-IM600...
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
Jan 16, 2011 | Altec Lansing Inmotion-IM600...
How do I open the altec lansing inMotion im600? I
There is a button on the front of the unit that is just below the LCD readout that shows FM / iPod status. Press the button. If it does not open the unit, you may need to tap the back of the unit when doing this or else get something to gently pry open the unfolding section WHILE THE BUTTON IS PRESSED (otherwise you'll break the mechanism and won't be able to lock it again. It sounds like whatever you put in to create the connection may be jamming up your opening.
The unit comes with several adapters for different iPod models, you may want to try a different adapter; you shouldn't need to put anything else in it to maintain a connection. If you don't have those adapters anymore, you can probably get them off the altec lansing web site.
Jan 12, 2011 | Altec Lansing Inmotion-IM600...
In Motion im600 unit seems to work for a few hours then just shuts down. If I wait a day or two it will start working again, then only for maybe a few hours. I've taken the battery out for a while then put...
5V AC adapter for Altec Lansing inMotion iM600 speakers http://lcdpayless.com/productpage.php?productId=172
13V AC adapter for Altec Lansing inMotion iM600 speaker http://lcdpayless.com/productpage.php?productId=170
Feb 07, 2010 | Altec Lansing Inmotion-IM600...
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Poor FM reception with Altec Lansing IM600 when using ac adapter
here is what I recommend, and It may be irrelevant but it could work.
the ac adapter cable may be creating interference with the radio signal, so what you can do is go ahead and try connecting the ac adapter as far away as possible from the device in a way that the( keep the cable as far away from the device, just leaving the plug into the hole)
and try putting some antistatic tape onto the end that goes into the device.
good day
Dec 28, 2008 | Altec Lansing Inmotion-IM600...
Can i hook a surround sound to my zune
It is usually as simple as getting a 3.5mm stereo headphone jack to RCA adapter, like this one:
http://www.radioshack.com/product/index.jsp?productId=3359117 (this will work just fine, even though it says 'ipod')
Or they have "Zune Ready" adapter kits, like this one:
http://www.radioshack.com/product/index.jsp?productId=3004031
Once you have the cable, you stick the headphone plug (3.5 mm stereo mini-phono) into the headphone jack on your Zune, then you insert the red and white RCA jacks into an open input on your surround receiver... most have an auxilliary input jack set on the front of the unit. All you need to do at this point is select the "aux input" for the source on the surround receiver, start your Zune, and make sure the volume on the Zune is somewhere in the 50 - 75% range, and you should be good to go.
Dec 08, 2008 | JVC THD-50 System
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune will not power up or show device connected when in zune software
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
FROZEN ZUNE 80gig
Message on your Zune device: "Screen 5 Contact support" View products that this article applies to. function loadTOCNode(){} Article ID : 926993 Last Review : June 20, 2008 Revision : 5.0 SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following message on your Zune device: 5
Contact supportuparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); This issue occurs when your Zune device cannot recover from an error.uparrow.gifBack to the top
THINGS TO TRY loadTOCNode(1, 'whattotry');There are two easy things to try that might help with your problem before you contact Zune Support: 1. Try restarting the Zune device. To do this, set the hold switch to the unlocked position, and then press and hold the Backzune_button_back.gif button as you press on the top of the Zune pad. When the Zune device begins to restart, you can release the buttons. 2. If you receive the same error message when you restart the device, try restoring the Zune device software. For more information about how to restore the Zune device software, click the following article number to view the article in the Microsoft Knowledge Base: 927001 (http://support.microsoft.com/kb/927001/) How to restore the Zune device software If restoring the device was unsuccessful, sign in at the following Web page and determine whether your device is still in warranty: http://service.zune.net (http://service.zune.net)If your device is in warranty, it may qualify for service. You can submit a request for service at this Web site.
May 30, 2008 | Microsoft Zune JS8-00001 Digital Media...
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
